Will Thinset Bond To Old VCT Glue Residue?
Old 03-02-2009, 08:56 PM   #1
Buck25's Avatar
Trade: General Contractor -- Remodeling
Looking at a small tile job. It's a slab, and the original flooring (circa 1960's) was VCT. The VCT has already been pulled up, but there is a residue of black glue. Can I thinset over that (I plan on using Ditra)? Or do I need to completely remove it? Or just run a sander over it to scratch it up? And if I need to completely remove it, what's the best way?
Thanks,
David
Buck25 is offline
Old 03-02-2009, 10:31 PM   #2
bathroom guru
jarvis design's Avatar
Re: Will Thinset Bond To Old VCT Glue Residue?
I would not go over the residue. Scrape or grind until you get to bare concrete. Then Ditra - then your tile, and if you want a really nice job, grout with Laticrete spectralock epoxy grout.
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
The Following User Says Thank You to jarvis design For This Useful Post:
Buck25 (03-02-2009)
Old 03-03-2009, 12:31 AM   #3
William Mear's Avatar
Trade: Contractor
There are a number of thinsets out there that are designed to go over old cutback adhesive. MAPIE II AND CUSTOMBLEND. You can also emboss it with ardex featherfin.ish and then use your thinset of choice.
DO NOT DRY SCRAP THERE IS ASBESTOS IN THE GLUE
William Mear is offline
Old 03-04-2009, 06:11 PM   #4
R&D Tile's Avatar
Trade: Tile installations
CUSTOMBLEND
Customblend is unmodified crap and shouldn't be used over cutback, Flexbond from Custom IS and works well.
R&D Tile is offline
Old 03-05-2009, 03:17 PM   #5
Old school Ranger
floorinstall's Avatar
Trade: flooring
We always scrap as much of the cut back adhesive as possible keeping it wet so as not to release dust in the air. Then skim the floor with ardex and set tile over that
floorinstall is offline
Old 03-05-2009, 05:42 PM   #6
Mellison's Avatar
Trade: Home Improvement General Contractor
Use Latipoxy by Laticrete.
As long as the glue will not interefere with the level of the tile you will be fine.
If it is that difficult to remove the glue then it has a suffuciant bond t the floor and the Latipoxy will bond to the glue like a MOFO.
Spent a little more $ on the Latipoxy and save alot of $ on labor removing the glue.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Performance Bond Qualification? TierraTurf Business 8 07-08-2009 03:23 PM
Help glue removal isaac Finish Carpentry 2 12-12-2008 12:49 AM
Gluing teak with gorilla glue? TakePride General Discussion 5 10-11-2008 09:55 PM
Contractor's bond and net worth... enap66 General Discussion 0 03-22-2008 04:20 PM
Will thinset bond to Quartz tileguy51 Ceramic & Stone Tile 6 01-24-2008 06:42 PM
