Wide Plank Pine Over Plywood Subfloor
Old 11-11-2007, 09:46 PM   #1
omenabay's Avatar
Hello,
I am to install random width wide plank pine over a plywood subfloor. Immediately underneath the subfloor is stapled up radiant heat tube. The plan is to glue and nail the flooring down directly to the subfloor. I am looking for advive on best glue/mastic to use. Is typical subfloor adhesive good or should i use a polyeurethane variety. Any advice one mightr want to share would be appreciated.
Thanks
omenabay is offline
Old 11-12-2007, 09:06 AM   #2
Knowledge Factory
Floordude's Avatar
Re: Wide Plank Pine Over Plywood Subfloor
I use PL Premium, urethane. It will be a fight, if you full spread, the adhesive. Just a sharp serpentine, bead on the back of the plank, is all that is needed.
http://www.AustinFloorguy.com
Floordude is offline
Plywood direction effect on floor bounce over I-Joist personalt Framing 25 12-31-2008 05:28 PM
R & R subfloor for even result? John Pride Ceramic & Stone Tile 4 11-01-2007 06:50 AM
Subfloor Mischman Framing 12 10-20-2007 02:30 PM
Pine floors and dogs=problems ron schenker Flooring 12 03-05-2007 05:47 PM
wide plank subfloor question...again Grainywood Flooring 2 10-10-2006 12:03 PM
