What Is Waterborne Hardwood Floor Finish?
Old 07-13-2009, 09:25 PM   #1
hardwoodfloors's Avatar
Trade: hardwood flooring contractor/dealer
Waterborne finish is a high wear resistance floor finish that is typically 62%water, 4% solvents, and 34% solids. It stays clear and is non ambering over time. It is non-flammable, and chemical resistant. It has an extremely fast cure rate, allowing multiple coats in one day.
Waterborne finish is also a good environmentally responsible choice for your home. Since it is V.O.C. compliant it is recommended by the EPA. It formaldehyde free and virtually odorless. This all adds up to a much safer environment for all members of the family after the sanding is complete.
Application is easy as well as cleanup. Cleanup is as simple as washing out tools and applicators with water.
Typically with waterborne finishes most manufacturers recommend one coat of sealer and two coats of finish to achieve the proper buildup for maximum protection. Keep in mind that too many coats will result in a very plastic appearance of the final coat. In this case more is not necessarily better.
As with all projects, knowledge is power. I hope that this article has empowered you to make a good choice for you and your family now and in the future. Happy Flooring!
hardwoodfloors is offline
Old 07-13-2009, 09:50 PM   #2
davitk's Avatar
Trade: Perfessional Contracter
Re: What Is Waterborne Hardwood Floor Finish?
Nice copy and paste
davitk is offline
Old 07-14-2009, 06:00 AM   #3
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
I dont remember asking....
Mike Costello is offline
The Following User Says Thank You to Mike Costello For This Useful Post:
PrecisionFloors (07-14-2009)
Old 07-14-2009, 11:03 AM   #4
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Now thats what we need on the flooring forum,stuff we already know...
the big 12 inch is offline
The Following User Says Thank You to the big 12 inch For This Useful Post:
hardwood floor and door jambs woodworkbykirk Finish Carpentry 33 12-05-2009 09:26 AM
Hardwood over Asbestos Tile 4yanx Flooring 10 11-08-2008 08:39 PM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
