What Type Of Carpet Glue To Use ?
Old 11-30-2010, 10:34 AM   #1
dryespo's Avatar
I am getting ready to lay down some indoor/outdoor on a slab in a screened in porch. I have read some horror stories about glue removal after the fact.
If I anticipate replacing in 2-3 years, is there a more forgiving glue to use so removal is easier down the road.?
dryespo is offline
Old 11-30-2010, 02:57 PM   #2
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 48
Re: What Type Of Carpet Glue To Use ?
No.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 11-30-2010, 09:09 PM   #3
rutroooo's Avatar
Trade: Floor covering/Framing/Remodeling/Trim
No, all the glues will hold for years,macinging berg duncan made one way back but appearantly it did not hold up. Depending on the type of carpet you can stretch and staple it if you are going to be replacing in a couple of years. Have done many installations like this on sun porches and exterior installations. Works great!!!!!!
rutroooo is offline
Old 11-30-2010, 09:51 PM   #4
Flooring Installer
Trade: flooring
Rewards Points: 48
Can't stretch and staple, poster said it was a slab.
Armstrong certified
Old 12-01-2010, 12:18 AM   #5
Rob PA's Avatar
dont know how weather protected the porch is..but what about installing a overlayment and just throwing in a few tapcons or anchors and then putting the adhesive over there..if you wish to get rid of it in a few years just pull up subfloor. Im sure you would have to use a vapor barrier between the slab and sub. Tranistions would also have to be used..but im sure you would of ended up with a form of a transition anyways. Just thinking outloud
Rob PA is offline
Old 12-01-2010, 06:42 AM   #6
Flooring Installer
Trade: flooring
Rewards Points: 48
I would just use double-face tape. If/when it comes loose, just put down some more.
Armstrong certified
Carpet Laying Tips Bozzy Flooring 122 11-16-2015 05:59 PM
Let's Talk Glue Inner10 Tools & Equipment 56 06-25-2014 06:12 PM
$199 Carpet Installation For Your Entire House. Celtic Flooring 68 06-28-2009 08:09 PM
Help glue removal isaac Finish Carpentry 2 12-11-2008 11:49 PM
How to edge Carpet at radius abutting Hardwood caswensk Flooring 2 10-12-2008 10:14 PM
