What To Charge To Pull Up 325sqf Of Laminate Flooring??
Old 07-16-2008, 12:28 AM   #1
TileMan77's Avatar
Trade: Tile Installer
Im bidding a job that consist of tearing up about 120sqf of 8x8 tile and 325sqf of Laminate flooring(not glued down) and 900sqf of carpet. Now Im doing the install of 20x20 porcelain tile where the laminate is and also Im laying the new laminate through out the rest of the house. The tile will consist of 450sqf then im laying in 900sqf of laminate. I will basically be tearing all of the house's flooring up and installing tile and laminate throughout the house. I normally charge about:
remove carpet = .50sqf
remove tile = 1.00sqf
remove laminate = ??? Im guessing about .75sqf but not sure havent ever pulled up laminate before...
I actually am a full time tile installer have been for 15 years and am a second generation tile setter, so to say. Learning from my father so I have always been around tile. I started to install laminate about 5 years ago. I dont do it all the time but have done a hand full of laminate jobs.. but like I said have never takin it up before... Thanks for all the help guys.. I have just now ran into this site and never knew it existed... Its awsome I am turning in bid tomarrow morning ... Thanks again.
Sorry for the length of this post...
TileMan77 is offline
Old 07-16-2008, 12:47 AM   #2
tile mason
MattCoops's Avatar
Re: What To Charge To Pull Up 325sqf Of Laminate Flooring??
Originally Posted by TileMan77 View Post
What to charge to pull up 325sqf of Laminate flooring??[...]
YOU should charge your batteries.
OR
You may need an energizer bunny
If you're a REAL tile man you don't need to rent a [YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hNLEzx0sE5U&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/hNLEzx0sE5U&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
MattCoops is offline
Old 07-16-2008, 12:51 AM   #3
tile mason
MattCoops's Avatar
Dear Moderator:
need help with playing the YouTube file for MEMBERS ONLY eyes'
Thanks in advance
ProWallGuy
Old 07-17-2008, 08:57 PM   #4
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Imo laminate is the easiest floor covering to remove. Hauling and disposal is another thing to think about to. For rip up, haul & disposal I typically charge 1.25-1.50/sf, depending on the situation and the job's proximity to a dump.
p.s. You want a job taking up tile?
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
WTF is up it shaw laminate floorinstall Flooring 14 05-25-2008 02:34 AM
Laminate Flooring Unregistered Flooring 16 01-12-2008 01:02 PM
Laminate Flooring Question DecksEtc Flooring 8 01-07-2005 06:39 PM
Laminate Flooring Gina Flooring 9 04-28-2004 12:06 AM
What is the best laminate flooring? Floorwizard Flooring 4 01-24-2004 02:26 PM
