Wet Subfloor
Old 08-24-2007, 07:18 PM   #1
Alex PCI's Avatar
Wet Subfloor
I just noticed a small shower leak that has caused my subfloor to be pretty wet. The subfloor has soaked the water up to about 2 1/2 feet away from the shower and is pretty damp right now. I have pulled the vinyl flooring back about 3 foot to expose the subfloor to allow it to dry. I am happy that I found this leak now before it actually rotted the floor out, but how long should this take to dry before i can install new vinyl? Damn shower door seal is the culprit.
Thanks
Alex PCI is offline
Old 08-24-2007, 07:35 PM   #2
reveivl's Avatar
Trade: Renovations
Re: Wet Subfloor
What material is it that got wet? If it was the particle board underlayment it may need replacing as it often softens and swells when wet.
reveivl is offline
Old 08-24-2007, 09:27 PM   #3
Alex PCI's Avatar
Re: Wet Subfloor
its a thin plywood of some sort, not particle
Alex PCI is offline
Old 08-24-2007, 09:40 PM   #4
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Re: Wet Subfloor
You're probably looking at the underlayment (most likely 1/4" luan plywood).
I would remove the entire floor, down to the subfloor (vinyl and underlayment). If you don't, you'll have mold growing between the subfloor and the underlayment. Let it dry out & treat with a mild bleach solution & use a fan to dry it out. How long it will take obviously depends on how wet things got. If it's a long term thing, you may find the subfloor below the underlayment needs to be cut out & replaced.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 08-25-2007, 09:36 AM   #5
Alex PCI's Avatar
Re: Wet Subfloor
it is the underlayment not the subfloor that is wet. I had a ceiling leak downstairs because of this so i cut out part of the ceiling to see what the floor looked like. Everything looked good, I caught this very early on so its minimal now. The subfloor it self isn't wet, just damp from the wet underlayment. I did spray some bleach on the underlayment but it still smells musty. I guess I should pull it up
Alex PCI is offline
Old 08-25-2007, 10:24 AM   #6
Alex PCI's Avatar
Re: Wet Subfloor
Just pulled the underlayment up and found that it was put over old vinyl which looks like it stopped the water from going any further. Can i just cut out the bad underlayment, patch in some new and go over that with new vinyl
Alex PCI is offline
Old 08-25-2007, 10:29 AM   #7
Alex PCI's Avatar
Re: Wet Subfloor
here is a pic of the subfloor, its just a little damp around the corners but thats it
Alex PCI is offline
Old 08-25-2007, 12:38 PM   #8
Demonseed's Avatar
Trade: Commercial Flooring
Re: Wet Subfloor
For how discolored that wood looks I would cut it all out, and pull up some of the old vinyl it was put over to make sure the floor underneath isn't wet. It looks as if it has been leaking for a while and chances are the water seeped underneath the second layer of vinyl. In the long run the more you pull out the better off you will be. the musty smell will never go away until everything is completely dried and treated, I use a chemical called DX-50 that is very effective, but I know others that use bleach.
The biggest problem people have in trying to assess water damage is they try to go by the feel of the surface of the material. once the surface of a material is exposed to air, it will seem to dry very fast, but the parts beneath it still retain the moisture. An example of this is when people have a carpeted basement that floods, they call and say I think the flooded area is 9 x 9, because thats where they can feel the carpet is wet, but in general that means the pad is probably wet in an area 50% larger than that.
Demonseed is offline
Old 08-25-2007, 01:34 PM   #9
KentWhitten's Avatar
Re: Wet Subfloor
I agree, cut it out of there. That looks like SYP plywood and that stuff buckles like mad when it gets wet.
Salmon Falls Cabinetry
KentWhitten is offline
Old 08-25-2007, 02:11 PM   #10
Alex PCI's Avatar
Re: Wet Subfloor
it seems that shower doors cause this sort of trouble quite alot from what ive been reading. Is there a better way to waterproof the floor so this doesnt happen again
Alex PCI is offline
Old 08-25-2007, 06:16 PM   #11
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Re: Wet Subfloor
Yeah, tile it, and use ditra and kerdi
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 08-25-2007, 06:22 PM   #12
Alex PCI's Avatar
Re: Wet Subfloor
doesnt the water still go through the tile, I know the ditra stops it but what does it do then? Does it just stay on the ditra forever
Alex PCI is offline
Old 08-26-2007, 01:11 PM   #13
HJ1's Avatar
Trade: Tile Contractor
Re: Wet Subfloor
Alex
Are you sure its the shower doors? I cant imagine that that much water is getting outside the door without you noticing this for so long. You need to find out for sure before you spend any time and money putting things back together. It could be the drain leaking or something else as well.
HJ
HJ1 is offline
Old 08-26-2007, 01:32 PM   #14
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Wet Subfloor
Use Georgia Pacific DensShield to patch the drywall that you removed on both sides. Skim coat it with drywall setting compounds. That floor is still very wet in the pics, I can smell it from here. Either let it dry out completely then go over it or remove it. As long as it's dry and it's stable and flat it doesn't matter what you do. Silicone all the seams of your new vinyl where it meets the walls and is covered by the base, install the base and silicone the gap between the base and the new vinyl.
Mike Finley is offline
Old 08-26-2007, 05:57 PM   #15
Demonseed's Avatar
Re: Wet Subfloor
I was meaning to add this, no matter what you decide to do, you will want to invest in a shower curtain, even with the shower door, the curtain will solve 99% of your water problems. (if the door unit is the actual problem)
Old 08-30-2007, 09:50 AM   #16
Knowledge Factory
Floordude's Avatar
Re: Wet Subfloor
You need a pin type wood moisture meter to determine when the wood has dried out. Anything else is just a guessing gamble.
Floordude is offline
Oak flooring over cement subfloor Nick H Flooring 33 04-16-2009 03:48 PM
Subfloor requirements Second Look Flooring 6 06-10-2007 12:18 AM
Bracing I-joists after subfloor installed. personalt Framing 7 11-10-2006 12:58 PM
wide plank subfloor question...again Grainywood Flooring 2 10-10-2006 12:03 PM
subfloor recommendation for ceramic 72chevy4x4 Flooring 5 10-03-2006 09:34 PM
