Wet Saw Blade Life?
Old 11-19-2007, 05:07 AM   #1
ponch37300's Avatar
Trade: general contractor
Wet Saw Blade Life?
How long does your wet saw blades last, how many sq. ft. before you purchase a new one? What brand are you using? Thanks
ponch37300 is offline
Old 11-19-2007, 03:14 PM   #2
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Re: Wet Saw Blade Life?
Depends on what you're cutting. I use a Boesh blade and replace it when it stops cutting clean.
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 11-19-2007, 09:51 PM   #3
Knowledge Factory
Floordude's Avatar
There are different blades for different material. If you use the right blade for the application, they last quite some time. Dry cut blades don't last as long as wet cut blades.
http://www.AustinFloorguy.com
Floordude is offline
Old 11-20-2007, 05:08 PM   #4
Tileguytodd's Avatar
Trade: Tile & Stone Contracting
I use Felker TM5 & TM7 blades pretty much exclusivly.
How long do they last???
When work is slow a Really LONG time
When I'm busy as lone bull in a field of hieffers..not nearly as long
Anybody got a better answer LOL
Tilewerks
Tile and Stone Contracting
Warba,MN 55793
Tileguytodd is offline
Old 11-20-2007, 11:37 PM   #5
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Ron, I bet you have a BUNCH of blades that still look half new!!
Have you guys ever heard of something called "dressing the blade"? What I use is a patio block from one of the big box stores. I'll get one of the 12x12x2" thick patio blocks, and once the blade starts slowing down, I'll run it through the stone about 6-8 times, cutting off about a 1/4" at a time. After that, the blade will cut like it's brand new.
What happens is the diamonds on the blade get worn down, especially when cutting the harder materials, like granite or porcelain. After a while, the diamonds are almost worn smooth to the metal matrix of the blade's rim. The patio block is hard enough that cutting it will wear down the metal, but soft enough that it WON'T wear down the diamonds, thereby exposing more diamonds, and "sharpening" the blade.
One other thing-- I saw atleast one person talking about using the right blade for the right material. I use all purpose blades all the time, with one exception-- when I'm cutting the extra thick porcelains, like Cerdomus Tiles. Any other time, the all purpose blades will do just as well as the specialty blades and even last longer. The only time a specialty blade might do better is if you're cutting glass. But as far as the porcelain blades are concerned, they're a marketing ploy, and a reason to charge you more money for an inferior blade. Read the following article, and it'll explain why I make that claim:
http://powerpr.com/articles/articles.asp?include=971
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 11-21-2007, 11:02 AM   #6
I let my last blade go a little too long. When I checked it there were no more diamonds left, just metal. No wonder the ceramic tiles were chipping
I don't tile full time so I've only gone through about a dozen blades in my life. Thanks for the tip Bill
Old 11-22-2007, 12:47 PM   #7
ponch37300's Avatar
Thanks for the tip Bill. I've heard of that before but haven't tried it yet. I will hve to see how that works next time my blade starts getting dull. Happy Thanksgiving everyone
Best Miter Saw Blade 4319hendrie Carpentry 51 12-15-2009 10:32 PM
Blade Wobble New Miter Saw balanceact Finish Carpentry 7 06-03-2008 09:12 AM
So what diamond blade DO you use? lukachuki Masonry 15 01-03-2007 01:24 PM
Life insurance/ investment K2 Off Topic (Non Trade) 1 09-14-2006 04:16 PM
Very small/thin table saw blade Woodcrafter74 Tools & Equipment 25 12-28-2005 07:25 AM
