Vinyl/linoleum Seam?
Old 01-24-2008, 10:46 PM   #1
works4me's Avatar
Trade: GC/Remodeling
I'm doing a punch list on a for sale home - they asked if I could close a seam in the vinyl/linoleum floor between the kitchen and laundry room under the door (about 3' wide), its curling up a little on both edges. Can I just use one of the $15.00 kits from Lowes for this or is that a mistake waiting for me to happen too. I don't know if it's vinyl of linoleum and does that matter or not - o.k. obviously flooring isn't my thing. But they were hoping not to call a specialist for a 3' seam (it won't hurt my feelings if they have to though). thanks
works4me is offline
Old 01-25-2008, 12:00 AM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Vinyl/linoleum Seam?
curling is usually a "too late" event.
It is shrinking and seam sealer is not going to make it stick.
flatbar would work though
Floorwizard is offline
Old 01-25-2008, 12:57 AM   #3
works4me's Avatar
Thanks florcraft, that's all I needed to know. They didn't want a bar, but I'll tell them it's all I can do for them now.
works4me is offline
Old 01-26-2008, 09:27 AM   #4
GoodHouse's Avatar
Trade: Flooring
You can TRY this.... get some sheet flooring adhesive, spread it in the seam area thats curled...You can try using a heat gun and getting it to relax. Roll the vinyl down, used a flat piece of lumber with some weight to it. Once its relaxed and warm, place a flat board on it with a good amout of weight and let dry over night. The next day clean up all glue with some afta or goof off or something.
This is worth a try because it will cost you very very little. good luck
GoodHouse is offline
Old 01-26-2008, 09:39 AM   #5
TimelessQuality's Avatar
What do you guys use before it's too late (new floor)??
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 01-26-2008, 09:46 AM   #6
GoodHouse's Avatar
Trade: Flooring
Timeless, i dont really understand your question? are you asking what do you do to prevent it from curling? It should not curl if its properly bonded and sealed. But some cheap vinyl does funny things. The curling in this situation is most likely do to having not enough adhesive and no use of seam sealer to weld the pieces together
Old 01-26-2008, 09:50 AM   #7
Using good quality vinyl. Basically.. which seam sealer do you prefer??
-Steve
Old 01-26-2008, 11:16 AM   #8
GoodHouse's Avatar
Trade: Flooring
I dont think i have ever used anything but armstrong.
Old 01-26-2008, 04:47 PM   #9
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
The seam sealer you should prefer is the one the manufacturer recommends There are different types of wear layers that require different sealers. Use the wrong one and it could discolor the seam, not bond to the surface, or peel right off once it dries. There are also different methods required for different materials. Some require the sealer to penetrate the seam and coat the joint itself. Some are just topical. Some yet require you to wipe the excess off with denatured alcohol.
Point is, there is no one size fits all seam sealer.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 01-26-2008, 08:58 PM   #10
Knowledge Factory
Floordude's Avatar
Correct, Seam Sealers are product specific. One product same as one price, does not fit all vinyls.
The reason vinyl curls, is from plasticizer loss, in the plastic wear layer. This shrinks the wear layer, and not the backing, pulling on the top only. Curl...
When this starts, it is a sign the vinyl is done with it's useful life. It becomes brittle. The heat from a heat gun, helps relax it, but only till it cools off. Glue will hold it for a little while, but the big thing is seam contamination with the glue used to adhere it back down. Not only does the seam sealer has a hard time bonding, it also turns the seam black after a few days.
http://www.AustinFloorguy.com
Floordude is offline
chimney flashing on standing seam roof kermmonk Construction 22 02-19-2010 03:39 PM
Standing Seam Rate around Greensboro NC TurnkeyConst Roofing 9 04-04-2007 07:17 PM
Standing Seam Metal over 3-tab?? EcoWise inc. Roofing 24 03-27-2007 06:07 PM
I seam to have forgotton what this forum is all about? KellyPainting Painting & Finish Work 17 09-05-2006 11:41 PM
Standing seam metal roof? kermmonk Roofing 1 08-14-2006 10:34 PM
