Vinyl Floor Removal
Little help here please from the pros.
I just bought a house and the basement floor has 30 year old glue down flooring. The upstairs had it laid over 3/8 particle board. That was no big tore the underlayment up and replaced it. That damn basement is stuck down solid to the concrete. The room is only 10 x 10 so it's kind of tight quaters. What's the best way to get this stuff up. The floor scaper just isn't cutting it. Ideas? |
Flooring Installer
Trade: flooring
Re: Vinyl Floor Removal
I assume you realize that is probably linoleum, full of asbestos.
Trade: Remodeling / Carpentry
I just took one up Friday. The owner, whom I working for on this flip tried his 5" weighted floor scraper.....not too good.
I got out my Fein Multimaster I got a few weeks ago with the scraper blade. Like butta......I couldn't believe it, just like on TV. You might want to try one of the new knock-off's as they're cheaper. |
Trade: hardwood floor contractor 28 yrs.
Go to your local tool rental place....home depot may have one also,and rent a floor stripper machine.Shouldn't take more than a few hrs.tops...
#5 | |
Re: Vinyl Floor RemovalQuote:
But damn this stuff is down. Good glue for sure. The Multi Master sounds like an idea. A buddy of mine has one I can borrow. The power scraper might be to big to fit in the room. Could wind up being good old elbow grease and my demo wood chisel. Thanks for all the input guys. |
Flooring Installer
Trade: flooring
Flooring with asbestos was sold into the mid to late 80's. Why not have it tested? It's not expensive.
Rusty,
Thanks for the info. Will have it checked on Tuesday by one of our Subs. It's a small amount only 5' x 8' of actual flooring. I inhale enough stuff just cutting lumber I don't need to suck in anymore crap than I need to. Rusty, What's your best bet to get this stuff up? You've gotta love that pattern
Old school Ranger
Trade: flooring
Why are you removing it? What kind of floor are you going to install? I would just use an embossing leveler and skim coat the floor and put down my new floor.
The flooring breaks at the doorway with a fairly good step. The hallway used to be carpet and I want to carry the flooring into the hallway across into the laundry room. I don't want the step or slope at the jamb. Yes I could feather it out, but I'd preferr to remove it. I have to live here for the next 10 years so why not do it right the first time.
Tile Contractor
Torch it.
Heat those tiles and they will come right up with the help of a scraper.
#11 | |
Some vinyl products had it. Some adhesives had it.
I like Green things
Get the scraper thing that goes in your sawzall, Ace sells them aroung here. They work great and are like ten bucks.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
Dufus Extrodinaire
small rotary hammer drill with a scaling bit will pull it up
If I had one I would share it |
Flooring Installer
Trade: flooring
Re: Vinyl Floor Removal |
Trade: Home Improvement General Contractor
Google.
Took less than three minutes. "In the meantime, asbestos is still an ingredient in nearly 3500 different products, including floor tile, linoleum and related adhesives."
"Enjoy Every Sandwich" Warren Zevon |
#18 |
Show me what to read.
#19 | |
I see now..... "Asbestos was also used in the production of many commonly-used products in both the construction industry and the home. These include: roofing materials; siding; bricks; insulation, including sprayed insulation; vinyl flooring; drywall materials; cement panels; piping; fireproofing substances; talc-based products such as baby powder; wire insulation; emergency generators; fertilizers containing vermiculite; and certain textiles. Asbestos was also used in the production of many small appliances, such as toasters, coffee pots and hair dryers. Although rarer, people can also be exposed to asbestos in the natural environment because asbestos is a mineral." A very large percentage of folks conflate all sheetgoods with linoleum.
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 09-08-2009 at 03:44 PM. |
| Vinyl or replace aluminium | rayh78 | General Discussion | 28 | 07-23-2009 07:28 AM |
| Cost Comparison: Re-Painting vs. Vinyl Siding | Pearce Services | Business | 5 | 04-23-2009 07:37 AM |
| Tile over vinyl pros and cons | tileguy7 | Ceramic & Stone Tile | 23 | 01-17-2009 09:53 PM |
| Painting vinyl siding | workpot | Painting & Finish Work | 18 | 11-06-2008 07:04 AM |
| Fiberglass vs Vinyl replacmemnt window | davinci | General Discussion | 3 | 08-12-2008 01:31 AM |
