Vinyl Floor With Felt Backing Showing
Old 04-08-2006, 08:36 AM   #1
jerry1967's Avatar
Trade: flooring
i am doing a flooring job where the customer has started to take out the old vinyl floor but then quit with a good portion of the felt showing. now he wants to put the new vinyl floor over what is left.i know i can put a leveler over the back the of vinyl but i don't know what to put over the felt that is showing. can anybody help me out here please?
jerry1967 is offline
Old 04-08-2006, 05:11 PM   #2
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Re: Vinyl Floor With Felt Backing Showing
Either finish scraping the old floor up or cover it with a subfloor.
Period.
Mike Costello is offline
Old 04-08-2006, 05:41 PM   #3
jerry1967's Avatar
Trade: flooring
everything is over cement so what kind of subfloor do i put down?
Old 04-08-2006, 07:00 PM   #4
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Whooops.
I guess a full scrape is in order.
Floorwizard is offline
Old 04-08-2006, 07:04 PM   #5
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Take a garden sprayer and soak it down with hot water. Let it sit for 15min and scrape it up with a 5" heavy duty scraper available at Lowes. I would then skim coat the entire area with Ardex feather finish, scrape down again with one of your now dull blades. Sweep, vac and lay new vinyl.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 04-09-2006, 06:58 AM   #6
Trade: Flooring
Oops, ya left that detail out the first time.
Looks like yer scrapin. I have had luck with a four inch bladed scraper and some elbow grease. Try to get it all up .
Old 04-09-2006, 07:24 AM   #7
jerry1967's Avatar
Trade: flooring
i also didn't tell you that it has asbestos in it so i was trying to avoid scraping it up
Old 04-09-2006, 12:05 PM   #8
Keep it wet, bag all of the scrapings in black contractor trash bags and declare it at the local landfill. If you're still looking for the easy (but not cheap) way out use some self leveling over the entire area and encapsulate it.
Precision Flooring
(772) 237-9900
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Fiber Cement almost same cost as Vinyl? MKECONTRACTOR Windows, Siding and Doors 17 12-20-2008 06:34 PM
Scalloped Vinyl Shamrock Windows, Siding and Doors 1 09-18-2006 04:20 PM
roofing felt bwashington Roofing 2 08-10-2006 10:52 AM
vinyl decking with hot tub nriddock Decks & Fencing 2 06-16-2006 02:10 PM
