Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 10-01-2009, 12:32 PM   #1
Trade: Spec GC
Very wide white pine T&G flooring
We've a local mill here, a pretty big one, that does white pine. http://wardlumber.com/facility.asp gives a look at their mill, which can handle logs up to 36 inches diameter.
They produce white pine T&G flooring, in quite wide random widths, for those that want the antique farmhouse look. I've seen it at up to 28".
Not exactly random, but made in 2-inch increments, so that you've a chance at end-matching when needed. Ends are plain cut, not "endmatched with T&G." and lengths are long.
What precautions should one take in using ultra-wide white pine flooring?
UpNorth is offline   Reply With Quote
Old 10-01-2009, 03:56 PM   #2
Designers
astor's Avatar
Trade: Wood Cork and Leather Flooring
Looks like they know what they are doing,plenty of pics of installed floors posted..specially face nailed 14" wide pine floors!!Why don't you ask their experience or for their installer recommendations?
Featuring Click Leather Floors
http://www.designershardwood.com
astor is offline   Reply With Quote
The Following User Says Thank You to astor For This Useful Post:
the big 12 inch (10-03-2009)
Old 10-01-2009, 07:08 PM   #3
framerman's Avatar
Trade: Framing, Custom Carpentry, Architectural Design
The thing I worry most about White Pine is the shrinkage and warping and that wide, it may shrink 1/2". To help with that, I'm sure they make the boards thicker. At a minimum I'd be at 1" nominal if not more.
Lodgepole Pine would be a better choice, but I don't think they would be able to get it there.
My 2nd cousin who lives 1/2 mile from me has his own mill and can cut 36" logs 16' long. Some of the other guys around have a similar setup, but I think a more normal size is 30".
I would be looking at as much of the quarter sawn grain as possible.
If one advances confidently in the direction of one's dreams,
and endeavors to live the life which one has imagined,
one will meet with a success unexpected in common hours
~Henry David Thoreau
framerman is online now   Reply With Quote
Old 10-01-2009, 07:26 PM   #4
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
That wide of a board requires glue and face nailing, I have seen some that were blind nailed t&g with glue.
That wide of a plank should be 4/4 and really should be face nailed.
Originally Posted by Gus Dering View Post
It may be just a gateway tool to the hard stuff. Be careful
WarnerConstInc. is offline   Reply With Quote
Old 10-02-2009, 05:03 PM   #5
Old school Ranger
floorinstall's Avatar
Trade: flooring
Nobody has mentioned screws and pegs. That is the way I was taught and it makes a great looking floor and you can charge good money for the specialty. You can generally cut your plugs out of the waste.
floorinstall is offline   Reply With Quote
T&G pine - inside, oustide corners? sorethumbs Carpentry 5 05-05-2009 11:23 PM
6" T&G Oak flooring question Leo G Flooring 11 03-08-2009 02:13 AM
1x12 white pine shelving for flooring? georgia dawg Flooring 0 01-29-2007 09:37 PM
