Vapor Barrier Product Suggestions Please
Old 10-30-2009, 10:57 AM   #1
Dairylander's Avatar
Trade: Renovator
Question
Here's the scenario:
The room was originally a back porch - slab on grade. It was converted to a four season room. The HO says that the previous contractor put in a system of 2x4 joists, then plywood subfloor, then carpet.
The HO wants me to install prefinished hardwoods and I'm wondering whether I should use a liquid vapor barrier or plastic sheet goods, and if you have any favorite products that would be great.
I already spoke with the flooring manufacturer and they were no help. They just said, and I quote, "Yeah, you should use a vapor barrier, but I don't know what kind."
I'm also concerned that sealing the plywood may trap the rising moisture from the concrete and rot out the sub floor. I may have to find some way to ventilate the joist space.
Please let me know what you think.
Thanks.
Dairylander is offline
Old 10-30-2009, 01:48 PM   #2
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Re: Vapor Barrier Product Suggestions Please
You will definitly need to vent the joists by drilling holes or cut notches in every one and either venting to the outside or along the walls to create airflow...still,these type of installs always have moisture issues.I would alert your client to this condition.Good luck!
the big 12 inch is offline
The Following User Says Thank You to the big 12 inch For This Useful Post:
Dairylander (10-30-2009)
Best product for stripping stain MCerminaro Decks & Fencing 6 03-14-2009 07:00 PM
