Unlevel Floor
Old 04-01-2012, 08:51 PM   #1
NJDave's Avatar
Trade: light construction
Unlevel Floor
I need to install hardwood on a plywood subfloor that is out of level by as much as 1.5" over 6 feet. The subfloor is two layers of 1/2" plywood on floor trusses spaced 18" apart. In the center of the floor there is an interior wall. The floor deflects towards the center wall on all sides. The trusses are accessible from beneath across only part of the floor. I'd have to remove the ceiling to get access to most of the trusses from beneath.
I am considering a number of options including cutting the plywood around the walls, then shimming the top of the trusses and then installing new plywood. I am a little concerned that the existing plywood may be serving to distribute the load from the interior wall and that if I cut the plywood I may cause the deflection to get worse.
I've also considered installing lally columns in the basement but the customer does not want to split up what is now an open room.
Has anyone fixed a similar problem? Thanks
NJDave is offline
Old 04-01-2012, 09:01 PM   #2
katoman's Avatar
Trade: carpenter
Re: Unlevel Floor
If you have 1 1/2" fall over 6' you have a structural problem. Is this your problem? In other words are you looking to fix this? If so, consult an engineer.
If on the other hand, you just want to lay the flooring and disregard the structual, I would not cut the plywood. Shim the existing as needed and lay the floor.
Glue all shims so as not to have squeeks. Good luck.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
olzo55 (04-01-2012)
Old 04-01-2012, 09:17 PM   #3
NJDave's Avatar
Re: Unlevel Floor
This is a condo and the homeowner brought the structural problem to the HOA in the past. The HOA brought in a structural engineer who had plywood gussets installed on the floor trusses as a way to strengthen the floor. The HOA did not want to jack-up the floor to straighten it for fear of causing collateral damage. Seemed like a shortsighted approach, but that's what they did.
NJDave is offline
Old 04-01-2012, 09:55 PM   #4
CO762's Avatar
Trade: Remodel
Re: Unlevel Floor
Ouch. So it's not a building issue, rather a design one. Man, don't condo's ****? They're the second worst real estate investment, only behind time shares.
Is there a unit underneath this?
CO762 is offline
Old 04-01-2012, 10:02 PM   #5
katoman's Avatar
Trade: carpenter
Re: Unlevel Floor
Well then just shim it out to suit and lay the floor. What else are you going to do? I use PL to glue down long shims like that.
katoman is offline
Old 04-02-2012, 12:29 AM   #6
NJDave's Avatar
Re: Unlevel Floor
No, there's no unit underneath. There's a partly-finished basement under the floor that will get the hardwood.
Shimming may be the only way to go, but shimming 1.5" seems extreme and seems like it may be very difficult to get a good outcome.
NJDave is offline
Old 04-12-2012, 05:36 AM   #7
General
Superbird's Avatar
Trade: General
Re: Unlevel Floor
http://www.ardex.com/productDetail.a...9&ProductID=17
Superbird is offline
Old 04-12-2012, 04:38 PM   #8
72chevy4x4's Avatar
Re: Unlevel Floor
are there doors that the 1.5" will mess with? Why can't you just leave it be? maybe with that bad of a subfloor, engineered w/ full spread would be better-you can make it curve better to fit situations as yours.
72chevy4x4 is offline
Old 04-12-2012, 04:48 PM   #9
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Re: Unlevel Floor
Originally Posted by Superbird View Post
Unless you glue the floor down - he might end up having a hard time nailing the wood down =4500 PSI ?
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is online now
Old 04-12-2012, 09:15 PM   #10
NJDave's Avatar
Re: Unlevel Floor
The job is being done to prepare the place for sale. The realtor said it would not sell with the floor in its current condition. I kinda agree. You can roll a golf ball across the floor and it picks up speed.
NJDave is offline
Refinishing a carbonized strand bamboo floor sipulsinac Flooring 9 06-23-2009 08:10 PM
Cross-laminated PE vapor barrier under floating floor after leveling with sleepers sjkm Flooring 11 06-14-2009 10:03 AM
Dealing with Floor Joists dcapone Low Voltage 0 08-18-2008 01:45 AM
New Concrete Floor laid, cracking, and sealer Q's. Knyte260 Construction 21 10-06-2007 11:25 PM
Basement floor dilemma ron schenker Flooring 11 07-02-2006 08:36 PM
