Uneven Finish
Old 02-26-2006, 12:07 PM   #1
Grainywood's Avatar
Trade: Flooring Contractor
Uneven Finish
How do you prevent the overlap mark in water finishes?
The finish edge is wet, I don't let it get dry so I avoid that cresting edge.
But I notice these thicker areas that follow the direction of my applicator. It looks like a "puddling strip", well not exactly a strip, but about a 2 to 3 inch wide thickening. It has a slightly different sheen because of it. It isn't raised or anything, so I can't peel it off or anything. It just looks like the finish went on thicker, like a puddling effect.
I don't see it until the finish is dry. Maybe I'm putting on the finish too thick? I'm just afraid it will contrast even more if I go too thin. I've heard you can cut the edges of the applicator to taper at a diagonal which might help.
Any suggestions?
Grainywood is offline
Old 02-26-2006, 12:24 PM   #2
Flooring North Cackalacky
drunkrussian's Avatar
Trade: Hardwood floors, everything about them
Re: Uneven Finish
I think I know what your talking about. But I like to get low, and see the light hit the floor, then I can see those lines that just pile up. I just pull them out as I go. I also pull the water finish thin. I find it hard to apply it as even as I want if it is too thick.
drunkrussian is offline
Old 02-27-2006, 10:34 PM   #3
adams,b's Avatar
Trade: hardwood floors
Re: Uneven Finish
I wonder what kind of applicator you are using. We use those tube-like applicators. They have them now where they are pre-waited down, kinda heavy. Ours is not but you need to press on it some and eavenly. Anyway my guess would be you are not pressing down on one side of your applicator enough. Also too, every time you make a new lap dont come over a full length of the applicator go about 3/4 the way and use the lines in the floor to keep it straight. Try not to stop either. Good luck.
adams,b is offline
Old 02-28-2006, 01:42 AM   #4
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Re: Uneven Finish
Always let your puddle split your applicator and like adam said, use the lines to keep straight.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 02-28-2006, 06:41 PM   #5
justin savage's Avatar
Trade: tile contractor
Re: Uneven Finish
we roll all of our finishes , you should try it. the finish comes out beautiful. justin
justin savage is offline
Old 03-04-2006, 12:07 AM   #6
Donedat's Avatar
Re: Uneven Finish
What brand of roller do you use Justin? I might try it on my next job.
Donedat is offline
Old 03-04-2006, 07:42 PM   #7
hulk's Avatar
Trade: hardwood flooring
Re: Uneven Finish
we roll all of our jobs to we ues a short nap wooster roller 3/16 i think when you use it with waterbase make short cuts or it will lap
hulk is offline
Old 03-08-2006, 07:10 PM   #8
Re: Uneven Finish
we use 1,4 nap wooster or purdy white rollers for oil.rub them out or wrap tape around it to remove loose fibers, this helps to make sure there are no flat spots also. email me and i will give you my cell number if you like. justin moesavage@hotmail.com
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 04:41 PM
Stripping old deck finish joedonuts Painting & Finish Work 26 06-09-2007 11:34 PM
glazing over stained finish ChuckEA Painting & Finish Work 5 06-23-2006 09:21 PM
Can You Help Identify This Finish? Richie-C Painting & Finish Work 10 06-07-2006 09:34 PM
metal railing finish failed problem? a68cudas Painting & Finish Work 9 06-06-2006 03:37 AM
