Tung Oil Floors
Old 08-15-2008, 07:39 AM   #1
Member at large
tthomas's Avatar
Tung Oil Floors
Good Day........
I have a client that wants her hardwood floors to be tung oiled. My questions are as follows:
1. in doing some research I seems to get the matte finish you need to use 100% pure tung oil and not a mix that have some poly in it, is that right?
2. if so were do I find at least gallon containers of 100% pure Tung Oil? it is a little over 1600 sq ft.
3. What would the experts, you guys and gals, recommend?
Thanks
Todd Thomas
Thomas Construction
1Tim. 1:16
tthomas is offline
Old 08-15-2008, 07:55 AM   #2
genecarp's Avatar
Re: Tung Oil Floors
we just did a tung oil job, trim not floors, anyway a mat finish was not our experiance , we ended up with more of a satin finish, also for a floor you will need at least 4 coats to get the protective build that you would require, even at 4 coats i am not sure about the life expectancy of the finish.
genecarp is offline
Old 08-15-2008, 01:17 PM   #3
Member at large
tthomas's Avatar
Re: Tung Oil Floors
I was planning to lay about 5-7 coats over a 3 day period. I have told her that the floors will/could need annual maintenance.....she's fine with that as a friend of hers has them in Ky. and she loved the way they looked.
Thanks
Todd Thomas
Thomas Construction
1Tim. 1:16
tthomas is offline
Old 08-15-2008, 03:57 PM   #4
Edger Boy's Avatar
Trade: Wood Floor Contractor
Re: Tung Oil Floors
The most popular tung oil floor finish is Waterlox. It makes a beautiful job and is made for wood floors as well as other applications.
You can read about it here.
www.waterlox.com
Edger Boy is offline
Tung Oil C.C.R. Flooring 18 06-09-2009 12:21 AM
Heated floors 6stringmason General Discussion 18 01-19-2009 08:21 PM
linoleum directly over hardwood floors. Thewallfixer Flooring 1 02-27-2008 08:31 PM
CAT PIXX stains on hardwood floors knothead Flooring 7 11-08-2007 07:58 AM
Painting wood floors steve-in-kville Painting & Finish Work 6 12-25-2006 09:28 AM
