Trap Door Trim Kits?
Old 03-02-2011, 02:31 PM   #1
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Has anyone ever tiled around a trap door in the floor? If so did u get somekind of prefab trimkit or make it your self?
Groutface is offline
Old 03-02-2011, 02:37 PM   #2
Groutface
Groutface's Avatar
Rewards Points: 524
Re: Trap Door Trim Kits?
That's even assuming u could beef up the trap door enuf to tile it I guess!
Old 03-02-2011, 02:56 PM   #3
Janitor
Repairman615's Avatar
Trade: Renovation and Design
Rewards Points: 150
I have, it was an old house with a basement like enviroment below the trap door.
Laminate floor.
I made the trim out of some pine. Watch out for going too thin on the rabbit (with pine at least). Then I stained and sealed.
This house was very sad...I did what I could within the budget. He was well pleased but by no means was this a showroom.
I suppose you could try a carpet transition or other like that...keep in mind on the hinge side you will need bevels or clearance to allow for opening on the trap door (unless it is like a lift out).
Repairman615 is offline
Old 03-02-2011, 07:14 PM   #4
slowsol's Avatar
Rewards Points: 2,212
Never done a trap door in tile, but I did do an access panel. It was for a small addition that didn't have crawl access. Cut the plywood to the exact size of 4 tiles plus grout lines. Screwed it in with trim head screws where the plywood stuck past the tile (hard to explain). Screwed durock to it and stuck tile to it. Then used color matched caulk instead of grout for the perimeter of the four tiles.
I have done a trap door in a laminate floor. Wanted to do a pull out door, but the HO wanted it hinged. It's still working after a few years! Surprised the hell of out of me.
-John
slowsol is offline
Old 03-02-2011, 08:46 PM   #5
Groutface
Groutface's Avatar
Rewards Points: 524
<img src="http://www.contractortalk.com/attachment.php?attachmentid=43934"/>
<img src="http://www.contractortalk.com/attachment.php?attachmentid=43935"/>
Looks great! Good idea recessed hinges from underneath!
Old 03-02-2011, 11:15 PM   #6
The Finisher
lawndart's Avatar
Rewards Points: 668
Attachment 43934
Attachment 43935
Did the same thing on a hardwood flooring project a few years back.
lawndart is offline
Old 10-25-2011, 02:33 PM   #7
Yukon Cornelius's Avatar
Slowsol, how did you manage to get the trim on the hinge side to clear the flooring when opening the door? Your pic looks like you had to take the trim off the hinge side to open. Having a similar dilemma on a project....
Yukon Cornelius is offline
Old 10-25-2011, 02:35 PM   #8
Slowsol Posted: "I have done a trap door in a laminate floor. Wanted to do a pull out door, but the HO wanted it hinged. It's still working after a few years! Surprised the hell of out of me."
Old 10-25-2011, 07:59 PM   #9
slowsol's Avatar
The hinges I used were made for inset cabinet doors. They push the door up when it opens. Also, I back beveled that back piece of trim a little on the side close to wall. You couldn't see there was a little gap in the back unless you were laying on the ground.
-John
slowsol is offline
DIY foam kits boehsconst2 Insulation 6 01-06-2012 04:23 PM
Trap Primer? Squench Plumbing 6 12-20-2010 05:39 PM
Spray Foam Insul Kits. Timber Jockey General Discussion 1 12-19-2010 09:11 AM
To trap or not to trap condensate drain on a package unit? Electric_Light HVAC 6 07-25-2009 01:38 PM
redguard on densGuard trap moisture? wopachop Tiling 14 11-20-2008 01:09 PM
