Toothing In Hardwood Floor Repair Question ?
Old 03-07-2018, 07:22 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,980
Going to repair this floor. Sanding and finishing is by others.
I of course want to tooth in what is practical. There are some longer existing pieces I would prefer to just cut shorter...rather than go back into the good flooring a foot or two addl.
Can I cut off the longer strip ? I'm thinking the adjacent pieces will be pulled out. How best to cut off and leave a partial piece ?
Toothing in hardwood floor repair question ?-hardwood-floor-repair-030718.jpg
Steve
We Fix Houses is offline
Old 03-07-2018, 08:17 PM   #2
AustinDB's Avatar
Rewards Points: 654
Re: Toothing In Hardwood Floor Repair Question ?
you can make a square cut on the longer pieces with your multimaster works well and put a slight back angle on the cut. A steady hand keeps it from hitting the adjacent board and running a vacuum can keep it from burning the blades up as quickly-that old oak can be hard.
AustinDB is online now
Old 03-07-2018, 09:08 PM   #3
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 748
I use a square to mark the line and then a oscillating multi tool to make the cut slightly back beveled so the new pieces will meet up nice. Everything Austin said...
I use my track saw to cut ones that aren't capture by pieces on either side. So if you have a long board that you can cut near the edge of the patch but you've got short ones on either side of it that are coming out, you can use a square to square the guide rail of the track saw and make the cut. Same technique would work with a circular saw, just a lot more dust.
Xtrememtnbiker is offline
Old 03-08-2018, 10:29 AM   #4
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,338
It's not terrible to cut out 20-36" lengths and then beat the new boards into position with a bully sledge and beater block. I like to put some adhesive in the slot to keep it from squeaking and minimizing top nails.
Metro M & L is offline
Novice question - hardwood flooring and exterior threshold furlong General Discussion 29 08-15-2015 08:57 AM
hardwood flooring question pre/unfinish sbrodacz Flooring 23 12-05-2013 04:18 PM
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 12:05 AM
Hardwood floor installing question duha79 Flooring 1 05-12-2010 02:15 PM
5 Best Hardwood Floor Tips And Save Money Too! Benoakley Flooring 6 08-17-2009 12:49 PM
