Tips On Using A "U" Sander On 3/4 Oak Flooring
Old 11-15-2004, 11:36 AM   #1
ROB W's Avatar
Question
i what to use a waterbase finish about 320sqf .someone used a drum sander against the grain . i thought i can start with 60grit ,100, 180/or better.the customers know it will not be a basketball court .and also wiping it down with a damp cloth before and after last sand ?????,thank you rob w
ROB W is offline
Old 11-15-2004, 12:58 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Tips On Using A "U" Sander On 3/4 Oak Flooring
What is the purpose of a wet wipe? I would avoid it unless for some reason you want to raise the grain between sandings. Cheese cloth would be my preferred wipe.
Mike Finley is offline
Old 11-15-2004, 04:04 PM   #3
ROB W's Avatar
its what miniwax recommands to do ,water or mineral spirits ,wipe down before base coat and then the top coat .i used oil before not waterbase .have you used waterbase before any tips or brands that work well rob w
ROB W is offline
Old 02-05-2005, 07:00 PM   #4
kesac's Avatar
Don't use the drum. Use the Squarebuff. Go with the 36, or 50 grit to level it, because they make the coarsest dust that stays on the floor instead of in the air. Once you get it leveled, quick with the 80-120, and thats about it. You can make a baskeball court out of that sows ear, and probably very quickly.
kesac is offline
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Flooring in Log home C.C.R. Flooring 7 09-05-2006 09:58 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
Laminate Flooring Gina Flooring 9 04-28-2004 12:06 AM
