Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 09-14-2006, 07:22 AM   #1
Trade:
Tiling transition to pergo
I am tile a bathroom that walks out into a living room with existing pergo floors. I am sure there will be a saddle put in, my question is should I carry the tile out into the doorway to butt up with the pergo or should I leave some space inbetween and stop the tile at the beginning of the door way?
kpikul is offline   Reply With Quote
Old 09-14-2006, 07:47 AM   #2
Too many factors you haven't mentioned.
Where does the pergo end (in relationship to the living room side of the jamb)??
What is the height differential??
Normally, - - the transition between floors should be below the door itself (when closed), - - so you're only seeing 'one floor' from either side.
If the pergo ends right along the living-room-side of the jamb I would either make a wide oak (or whatever matches) saddle, - - or, - - beings it's a bathroom, - - install a (4" wide) marble saddle. The marble saddle would butt about 1/8" shy of the pergo, - - leaving room for caulk (and expansion).
If you'd prefer a custom (you'd have to make it) 'over-lapping' oak saddle, - - then yes, - - let the tile fall at (the very) least 1" short so you can make that part thicker and allow for pre-drilling and attachment screws.
In the case of the oak (or similar) saddle, - - you would rabbett out each side separately to allow for any height differential, - - in the case of the marble saddle, - - you could probably find a 'compromise-height' that would allow both sides to 'butt'.
The last choice (IMO) would be to buy the 'pre-fab' transitions, - - but I doubt they would have anything that would satisfy yours (or the customer's) need, in this instance.
Tom R is offline   Reply With Quote
Old 09-14-2006, 08:35 AM   #3
Catch what you'll eat.
MattCoops's Avatar
Trade: Tile & Paint
Try a Schluter transition. You may need a reducer if the heights are different, if you can get both surfaces flush you can use a "T" strip.
They sell Schluter at Home Depot. It's usually at end of tile aisle.
Schluter has a website also.
Matt; tile contractor in Charlotte, NC
704-605-0907
Tweeting @MattCupan | read my articles
MattCoops is offline   Reply With Quote
Old 09-14-2006, 08:43 AM   #4
Teetorbilt's Avatar
In the majority of installs, tile and laminates will be very close to the same height and you can use their 'T' transitions. This works on a lot of carpet installs as well and makes for a clean look.
If there is too much variation I do as Tom does and make my own. I make them to fit into the pergo track thus eliminating exposed screw or nail heads.
Albert Einstein
Teetorbilt is offline   Reply With Quote
HELP - Transition at angle between floor and carpet rajrajput Flooring 1 07-19-2007 07:40 PM
Transition from the 3/4 PVC to NM remster Electrical 10 06-19-2007 03:17 PM
Tiling Outside LNG24 Ceramic & Stone Tile 3 04-12-2007 05:49 PM
Pergo Laminate dnebout Flooring 45 03-12-2007 09:55 PM
Door Jamb transition Bukemdano Finish Carpentry 72 01-01-2006 10:49 AM
