Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 05-27-2009, 07:30 PM   #1
Trade: no
Tiling outdoor patio
I've set a lot of tile in my day but never outdoor patio tile. I've got all the info I need to proceed with the install, but one thing eludes me...
What do I do about the expansion joint? Do I try to get a course of tile to land on the joint, or should I try to get it to land on the grout joint? I'm thinking it's a no win situation either way, with the tile cracking or the grout joint cracking if not prepared properly. Any suggestions?
user3321 is offline   Reply With Quote
Old 05-27-2009, 07:32 PM   #2
Trade: Remodeling general
you will need to install some sort of crack supression to keep the tile from cracking.
naptown CR is offline   Reply With Quote
Old 05-27-2009, 07:39 PM   #3
Trade: no
What type of product would you recommend?
Old 05-27-2009, 08:57 PM   #4
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
All expansion joints must be honored through the finish flooring.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is online now   Reply With Quote
Old 05-27-2009, 09:09 PM   #5
Trade: no
Thanks. I was hoping that wasn't the case but I'd rather do it right and have an exposed seam, than to potentially create a warranty issue. Is standard issue expansion joint suitable for the finished product?
Old 05-28-2009, 10:37 PM   #6
RLKMarble's Avatar
Trade: Custom Tile Marble
Send a message via AIM to RLKMarble
I would recommend a Schluter expansion strip and if possible red gaurd (poly blend product) the entire slab for crack isolation. Check Schluter.com for your application. There DILEX line will have something for you.
RLKMarble is offline   Reply With Quote
Old 05-29-2009, 08:40 PM   #7
jarvis design's Avatar
As mentioned look at Schluter Dilex for the expansion joint (make sure to match up the height of the moulding and tile) and while you are there look at ditra.
Do it Right the First Time....or someone else will!!
www.JarvisDesignBuild.ca
jarvis design is offline   Reply With Quote
Tiling Basement Bathroom Floor highpeaks Ceramic & Stone Tile 4 07-06-2009 01:09 PM
tiling fields for water drainage jbleichty12 Specialty Trades Picture Post 3 06-05-2009 10:22 AM
Tiling closet floor with 1/2 hardi backer?? Divine Tile Ceramic & Stone Tile 24 03-28-2009 11:16 AM
Tiling contractors how do you rotarex Ceramic & Stone Tile 13 01-10-2009 05:07 PM
tiling shower and seat rbeck3@ec.rr.co Ceramic & Stone Tile 85 10-22-2008 06:15 PM
