Tiles Not Holding To #52 Mortar
Old 03-03-2009, 02:56 PM   #1
rotarex's Avatar
i dont know whats going on here, i used #52 grey mortar from the Olympia Group, and the tile is limestone and about 15 tiles out of 110 has popped up already with no mortar on the tile it self, i did make the consistency a little stiff so i can level the floor properly but it was still wet if you touch it, i also used a spray bottle on areas of the motar when it was getting old and stale so its wet... thats one area
not i did a wet mix for elswhere and same thing happen tiles popped up
i did leave it in the garage for a week in the cold could that have anything to do with it???
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 03-03-2009, 03:41 PM   #2
Remodeling GC
kevjob's Avatar
Re: Tiles Not Holding To #52 Mortar
first always use white thinset for natural stone, might be a bad batch could be you let it kick off too long, you mentioned wetting the thinset down, how thick was the mortar on the floor? I like to use marble and granite mix because it is white and medium bed.
kevjob is online now
Old 03-03-2009, 06:28 PM   #3
rotarex's Avatar
well with the 52 its hard to say how thick it was, because it never slops after you run it, that's the reason why i like it so much over other products....usually ill get the versabond from HD and around 3 min you will see the humps go down after you run it on the floor.
Custom Decks
Renovation
rotarex is offline
Old 03-03-2009, 08:22 PM   #4
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Was the limestone dusty?
Did you use a wet rag and wipe the tile before setting?
Did you backbutter the tile before setting?
Flextile #52 is a good product if used properly
Chris
Chris Johnson is offline
Old 03-03-2009, 08:45 PM   #5
Forry's Avatar
Trade: General Contractor, Remodeler
Sprayed water on "stale" mortar? That's a nono as far as I'm concerned. I always re-rake it if it's skinned over. I've scraped it up and tossed it 'cause it didn't feel right too. I'd bet all the tiles in that area didn't stick. Did you set 'em in there good? Or did you just drop 'em on top of the mortar and think they'd stick? I'm thinking operator error.
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline
Old 03-03-2009, 08:59 PM   #6
I'm a Mac
Did you mix it up, let it slake for 10-15 mins and remix before use?
Chris
Old 03-03-2009, 09:06 PM   #7
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Bingo. This is the problem I'd say . If tiles that popped are not bonding when you flip them over to examine them it's a moisture problem.
Back when I used to do this, I would always be very careful with the thinset, never try to extend it's usage, throw it out and start a new batch, and I would wet the back of those tiles with a sponge soaking them and then back butter if any problems when pulling a test tile every now and then.
Saying you started off thick in your thinset and what you are describing is surely the symptoms of this.
Mike Finley is offline
Old 03-03-2009, 09:15 PM   #8
Knowledge Factory
Floordude's Avatar
Stone requires 100% bond. To achieve this, they highly recommend back buttering the tiles.
http://www.AustinFloorguy.com
Floordude is offline
Old 03-03-2009, 10:30 PM   #9
rotarex's Avatar
wasn't dusty, didn't wipe them.......all tho that would seem like the most logical answer to me
didnt back butter the tiles that also is something i learned that i should do
PS whats wired is the $5 bag of thinset has worked the best for me so far vs the $30 and up bags
i did a 750 sq ft place with all cheap stuff the client bought and not one problem in that place then again i did use the mix pretty fast vs in a house i have to cut and set which uses the lifespan of the mix in the bucket
i do think its my fault somewhere in this .....
Custom Decks
Renovation
rotarex is offline
Old 03-03-2009, 10:52 PM   #10
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Sounds like your mix was way too dry. How much leveling were you trying to do?
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 03-04-2009, 07:32 AM   #11
rotarex's Avatar
not much leveling at all, the weired part is they came out in all diffrent places, and 4 of them came out in a place i started a new batch and tiles was clean as ever, but now i know for next time to so a skim coat on tile for safety...................live and learn
wow after about 2500 sq ft of tiling this happen, something to learn new everyday
Custom Decks
Renovation
rotarex is offline
Old 03-04-2009, 09:24 AM   #12
Knowledge Factory
Floordude's Avatar
If your going to do natural stone, and make a living from it, it would behoove you to get the Marble Institute of America's technical manual. It is for all natural stone installations. It differs greatly from ceramic requirements.
The Following User Says Thank You to Floordude For This Useful Post:
kevjob (03-04-2009)
Old 03-04-2009, 04:56 PM   #13
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Floordude, do you have a link to the marble institute of america manual?Thanks
platinumLLC is offline
Old 03-04-2009, 06:52 PM   #14
Remodeling GC
kevjob's Avatar
http://www.marble-institute.com/
Clean mortar off of Glass block??? Nobreus Masonry 21 09-11-2009 07:59 PM
Mortar mix? rotarex General Discussion 1 01-06-2009 11:51 PM
1st Row of Bricks on Lentil Dry, In Mortar, or Either? TomBrooklyn Masonry 16 08-30-2008 04:01 PM
Storage Limits for Suspended Ceiling Tiles FlashJT General Discussion 5 01-29-2008 08:18 PM
Should I Demo Up The Existing Mortar Bed For New Marble? bluethumbnail Ceramic & Stone Tile 3 01-14-2008 08:12 PM
