Tile In Shower?
Old 09-17-2008, 06:48 PM   #1
gtmstang's Avatar
Trade: Remodeling contractor
Tile In Shower?
I'm doing a 3x5 shower and have hit a snag. Its in a basement and one wall is cinder block. 3 of the walls are studs so I put durock on them. The back wall is the block and it has tile aleady on it. When I try to chip off the tile I either get a little cinder block or grout from the joints. I'm worried I'll mess with the blocks integrity if it starts to chip and crack. So the question is, can I go over the existing tile?
gtmstang is offline
Old 09-17-2008, 07:12 PM   #2
genecarp's Avatar
Re: Tile In Shower?
if it is as solid as it sounds, rough it up and go for it, the makita grinder should do the trick...
genecarp is offline
Old 09-17-2008, 07:12 PM   #3
Mellison's Avatar
Trade: Home Improvement General Contractor
Re: Tile In Shower?
Sorry, it is tough to say without actually looking at the job, for a multitude of reasons.
Mellison is offline
Old 09-17-2008, 07:25 PM   #4
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Re: Tile In Shower?
It would seem to me that if the surface is ground rough enough for the thinset to grab, then it should work fine. Keep in mind that each tile should be checked to see if it is loose. If so it should be removed.
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 09-17-2008, 07:39 PM   #5
R&D Tile's Avatar
Trade: Tile installations
Re: Tile In Shower?
And, is this a shower wall, what type of floor is being used, pre-fab pan or tile?
R&D Tile is offline
Old 09-17-2008, 08:32 PM   #6
Tile Contractor
Bud Cline's Avatar
Re: Tile In Shower?
Tile in shower?
This all sounds very familiar. Is this the only thread you have going with these details?
Bud Cline is offline
Old 09-17-2008, 09:30 PM   #7
gtmstang's Avatar
Re: Tile In Shower?
I think this is the only thread. I may have asked a few weeks ago while I was quoting the job, but I dont think so. The tile is on solid and the few I got off came in peices, not easy. Its a tile floor and I put mud bed down today. Its the rear wall in the shower. So check for loose tile grind and go? Do I just grind it down or do crossed notches like a scratch coat? Sorry if these are stupid questions, I'm just a little lost. Thanks for all the advice so far.
gtmstang is offline
Old 09-17-2008, 09:34 PM   #8
genecarp's Avatar
Re: Tile In Shower?
no need to crosshatch every tile, just break the surface(glaze) clean really well, dust will do you in. then go for it.
genecarp is offline
Old 09-18-2008, 05:23 PM   #9
R&D Tile's Avatar
Re: Tile In Shower?
What mud, in the shower floor or outside of it, you have a photo of this?, nothing makes any sense here.
If a tiled floor shower, how was it constructed, I wouldn't tile over any tile in a shower.
R&D Tile is offline
Old 09-18-2008, 09:31 PM   #10
gtmstang's Avatar
Re: Tile In Shower?
The shower is in the basement which is a concrete slab. I did a mortar bed with liner for the shower floor and then built the curb also.. I'm sorry I've always just called it a mud bed. The only place I have existing tile left is on the back wall of the shower 3' wide 6' tall. One wall. I tore all the other tiles and mortar bed up from the floor and got the old tile off of three of the walls because they were sheetrocked and I was needing to put durock up anyway. The fourth is the rear wall in the shower and is adhered to cinder block with GOD knows what and I'm having a very tough time getting the existing tile off. Did this clear everything up? Everything in the shower is newly constructed, new mortar bed, three new walls, new drain, etc. Except the cinder block wall with the existing tile left on it.
gtmstang is offline
Old 09-19-2008, 05:05 PM   #11
R&D Tile's Avatar
Re: Tile In Shower?
How was the pan liner installed if there was tile on a wall, it's supposed to be behind the new walls and is there a pre-slope under the liner?
R&D Tile is offline
Old 09-20-2008, 02:32 PM   #12
gtmstang's Avatar
Re: Tile In Shower?
Bottom pan went right back where the old one was. Then my preslope, I couldnt get my next liner to go in right so my tile dist. told me to redgard on top of the presloped bed and put my final mortar bed down and redgard it also. It was the best solution to this problem. The original mortar bed had no liner under final mortar bed. Just one mortar bed with a real crappy liner. I'm guessing they had trouble with this cinder block wall also. I ran everything I'm doing by the HO and they have checked off on it so I'll carry no liability, hopefully. They beleive my fix is better than what they had. I sure hope so.
gtmstang is offline
Old 09-20-2008, 02:54 PM   #13
tile mason
MattCoops's Avatar
Re: Tile In Shower?
First off, you should demo that old shower pan abortion as far down to nothing as possible. Better to start fresh. It's a remodel, not a repair.
I would rip all the tile off the cinder block wall and shoot wood studs into it.
Then install your pan liner over a preslope and backerboard over the wood studs. (We use DensShield)
Then install your drain and create your mud bed for the shower pan.
And tile away.
MattCoops is offline
Old 09-23-2008, 06:24 PM   #14
gtmstang's Avatar
Re: Tile In Shower?
So much help. Thanks guys. I'm almost finished with the shower. Decided to get as much of the tile off the cinder blocks as possible, install studs and then go with my pan an mortar beds. It was a bear but I feel alot better about the job. My laborer whined the whole day "This is a waste of time" and "why do you always have to do stuff the hard way". Started to make me think....was this how I was when I was a laborer and will he ever learn every job can't be easy. But anyway thanks again guys for all the advice.
gtmstang is offline
Old 09-23-2008, 09:55 PM   #15
General Contractor
Snow Man's Avatar
Trade: Construction Management
Re: Tile In Shower?
Id make a my own a wall
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Tile Debate - Shower floor 1st or shower wall? Logan's Ceramic & Stone Tile 21 08-03-2008 02:27 PM
Subway tile Shower remodel MattCoops Ceramic & Stone Tile 20 01-05-2008 07:52 PM
Questions on Tiled Shower ksensen Remodeling 10 09-10-2007 09:54 AM
How to tile a shower floor??? CALKAM Carpentry 6 03-19-2007 08:23 PM
curb in tile shower floor. fastg60 Ceramic & Stone Tile 48 03-13-2007 12:46 PM
