Trade: Flooring Contractor
Tile Removal Issue At Laundry/kitchen Threshold
The homeowner wants to keep the tile in the laundry room but have wood installed in the kitchen. The problem is that the tile is installed without a break between the laundry and kitchen transition. There is no clean break between the laundry and kitchen tiles.
I removed the tile in the kitchen but not up to the door jam because the tile straddles both the kitchen and laundry room. No clean break. I have a masonry blade to cut part of it but then do I chisle the last couple of lateral inches remaining? I don't want to break the remaining tile extending into the laundry. Is there a better way? Thanks
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Tile Removal Issue At Laundry/kitchen Threshold
Without getting into all the cutting solutions that will be coming, one solution may have been to have saved enough whole pieces that came out of the kitchen, then breaking out the whole pieces in the doorway between them and then reinstalling newly cut tile from the ones you saved. The only down side would have been the grout not matching perfectly.
GC / Remodeler
diamond wheel on an angle grinder. works every time. If you can't get close enough, use a dremel or a rotozip with a small cutoff wheel. Deal with the dust, its the easiest way to go without damaging more floor then you need to.
Dan |
#4 | |
Home Improvement Guy
Trade: Renovations contractor
Re: Tile Removal Issue At Laundry/kitchen ThresholdQuote:
Don't worry, the baseboard will hide it! |
Remove the door stops, - - then you can angle grind all the way into the jambs, - - then just re-install the stops, - - voila!!
tile mason
Snap a line
Angle grind. Put a ceramic tile bit in your dremel to smooth out the line If need be, stone file the edges to smooth the line If you're laying wood, leave a gap for a T-transition
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
Thanks guys. Worked like a charm. Forgot about that dremel tool.
The painters and homeowners would have freaked out if I removed the door jams but that would have been my next option.
| quarry tile to quarry tile | rservices | Flooring | 8 | 01-15-2010 12:37 AM |
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| Tile Removal Questions | DecksEtc | Ceramic & Stone Tile | 11 | 06-07-2006 12:56 AM |
| Got some design ideas for tile wainscoting? | Mike Finley | Ceramic & Stone Tile | 2 | 05-09-2006 10:05 AM |
| Cutting Existing Tile. | kpikul | Remodeling | 16 | 02-05-2006 12:30 AM |
