Tile Prep Question
Old 09-24-2006, 11:20 PM   #1
ch0mpie's Avatar
Trade: Geotechnical PE
Tile Prep Question
I'm remodeling a kitchen. When I started the ho said she wanted vinyl or laminate on the floor, but now she has changed her mind and wants tile. Half of the kitchen is the original house and the other have is an addition. The room is about 12'x24' The addition had 2x8 floor joises spanning 12' with a layer of 1/2" ply. The original house had 2x8's spanning 12' with a layer of 3/8"ply. I added a layer of 1/2" ply to the whole room, but in the orginal house the floor was wavy and not level plus the addition was about a 1/4" to 3/8" higher than the orignial house. I shimmed the original house floor level before adding 1/2" ply to the whole floor. My floor is sufficient for laminate or vinyl but I'm not sure about tile. I don't what to raise the floor too much higher with a layer of cement board because it is already a 1/2" abovethe floor in the next room. What do you guys think my options are?
ch0mpie is offline
Old 09-25-2006, 12:55 AM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Tile Prep Question
1/4" hardi. I am assuming you have the floor already flex free, I had a hard time following your post. If you really just can't stand that extra 1/4" then look into Ditra.
Mike Finley is offline
Old 09-25-2006, 06:38 AM   #3
R&D Tile's Avatar
Trade: Tile installations
I know you don't want to hear this, but, if those 2x8s are are spanning 12' unsupported, they don't meet specs for tile, too much flex in the floor.
R&D Tile is offline
Old 09-25-2006, 05:18 PM   #4
ch0mpie's Avatar
Thanks RD. Without knowing it for sure this was my gut feeling as the floor does seem to have a slight "bounce". I would much rather find out now and deal with it properly than do an incorrect installation and end up paying for it later.
I saw in anther thread you recommended the TCA handbook, I think I'm going to pick one up. Are these kinds of deflection tables included in this reference?
ch0mpie is offline
Old 09-25-2006, 05:25 PM   #5
tgeb's Avatar
Here is a link to a span calculator, Ch0mpie.
http://www.awc.org/calculators/span/...orizontal+Span
I am sure with a search you can find others as well.
www.gebcon.com
tgeb is offline
Old 09-25-2006, 10:03 PM   #6
ch0mpie's Avatar
thanks tgeb. I checked out a few others too just to cross reference. They all gave me 12' allowable for 2x8's spanning 12', 16oc, 40 live load, 15 dead load. I considered L/360 deflection for ceramic tile. What criteria are you holding the for to RD?
ch0mpie is offline
Old 09-26-2006, 06:43 AM   #7
R&D Tile's Avatar
http://www.johnbridge.com/vbulletin/deflecto.pl
I trust this one, made for by tile guys.
Either way, you already stated it feels bouncy, Yes?, that would be enough for me to beef it up.
R&D Tile is offline
Old 09-26-2006, 03:52 PM   #8
tgeb's Avatar
I would err on the side of caution. Those 2X8s are pretty well maxed out at 12 feet.
I would follow RD's advice. He is the pro in this area. He has helped me through some projects on a different site, never bad advice.
I just happened to have had a link to the span calc you were looking for.
I would consider sistering those 8s, or support from below if possible.
www.gebcon.com
tgeb is offline
Old 09-26-2006, 04:24 PM   #9
R&D Tile's Avatar
R&D Tile is offline
Old 09-26-2006, 04:58 PM   #10
Moderator
Double-A's Avatar
While blocking is not effective for 'expanding the span' so to speak, solid blocking will help with deflection.
Will it be enough? Probably not without sistering, but doing both will make it much less bouncy.
New York Times, July 20, 2006
Double-A is offline
Old 09-26-2006, 07:52 PM   #11
ch0mpie's Avatar
Thanks again guys. I wasn't questioning RD's advice, I just wanted to know what source he was using. By the book this case may be boarderline, however as I mentioned before the floor is a little bouncy and I don't want any headaches. Fortunately the customer is not dead set on tile and does not want to spend the extra to money for me to sister everything, so we are going to go with a laminate.
On another note, that ditra stuff that Tom recommended looks pretty cool.
ch0mpie is offline
Old 09-26-2006, 08:47 PM   #12
R&D Tile's Avatar
Ditra is a great product, BUT, the floor still has to meet specs to use it.
R&D Tile is offline
Old 09-26-2006, 10:56 PM   #13
carl owens's Avatar
Trade: remodeler
2x8 -16'' Center ?
Remove Ply Install Cement Pads Block An 4x8 Supported Eight Foot Perpendicular Floor Joist.
Stretch String, Check Joist For Flex.
3/4 Ply Floor Rated.
1/4'' Hardie Or Float Mud .
Then Top It Off With Schluter Ditra.
Tile Grout No Call Back .
Hope This Helps .
Carl
carl owens is offline
Old 09-26-2006, 11:56 PM   #14
Tile Contractor
Bud Cline's Avatar
Carl could you repeat that information only this time please do so in english.
TO OUR VALUED CUSTOMERS:
Please manage your children.
Any children unattended throughout the day
will be given a Free Mountain Due at our regular quiting time.
Bud Cline is offline
Old 09-27-2006, 02:43 PM   #15
R&D Tile's Avatar
Carl, no need for Hardie or mud if using Ditra, one or the other.
R&D Tile is offline
Old 09-27-2006, 09:34 PM   #16
Flooring? What's that?
J DoubleD FLoor's Avatar
Trade: Flooring
Or you can repeat it in Engrish ... I'm bilingual
Quality is not expensive ... It's PRICELESS !!!
www.neoflooringco.com
J DoubleD FLoor is offline
Old 10-02-2006, 09:05 PM   #17
troubleseeker's Avatar
It has been my experience that ceramic tile and bouncy floors do not mix well for the long term. Beef up the floors and put down a layer of 1/4 inch Durock or hardi backer. Also much better for long term life tha tile glued to wood substrate.
troubleseeker is offline
Old 10-03-2006, 05:29 PM   #18
R&D Tile's Avatar
Glue the tile to what?
R&D Tile is offline
Floor Prep Question? JMG1959 Concrete & Paving 9 05-17-2007 04:29 PM
Question about Prep gregt848 Painting & Finish Work 5 02-28-2007 04:57 PM
drain tile question bobbrown Construction 5 09-05-2006 07:52 AM
Tile Design Question - Borders and Multiroom Jason Ceramic & Stone Tile 3 07-24-2006 04:32 PM
Backsplash Tile Question Robie Remodeling 5 02-13-2006 09:32 AM
