Tile On Plank Subfloor
Old 09-11-2009, 09:03 PM   #1
CliffHollen's Avatar
Trade: Kitchen and Bath Remodeling
Hey Guys,
I will soon be putting down some tile in an old house that has the original pine plank subfloor, which I have never put tile on. Some of the gabs between the planks are 1/2"ish. How should I deal with this? Can I just apply mortar and 1/4" hardibacker the way I would over a plywood subfloor? It seems like adding plywood and then mortar and backer would be nice, but that sounds pretty thick.
Advice is appreciated.
-Cliff
CliffHollen is offline
Old 09-11-2009, 09:09 PM   #2
Its all ball bearings
angus242's Avatar
Trade: Tile
Re: Tile On Plank Subfloor
An older home may not have the joist strength to handle a tile job. You first need to find out about the deflection. Chances are, you'll need an additional layer of EGP. If height is an issue, consider using Ditra instead of CBU.
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is online now
Old 09-11-2009, 09:10 PM   #3
N.Schiffer's Avatar
Trade: Custom Carpentry
Send a message via AIM to N.Schiffer
I'm not professional tiler but I would put plywood down, even if it only allows for 1/4" plywood. Any added thickness would help with uneven flex with planks. Just figure out how much thickness you can allow for, then go from there.
N.Schiffer is offline
Old 09-11-2009, 09:38 PM   #4
I'm not too worried about the deflection. Another room in the house has tile that must be 10 years old and still looks fine. I wish I could see what is under it.
The wood floor I will be butting up against is about 3/4" thick. Maybe I could use 2 layers of 1/4" backer?
Old 09-11-2009, 10:16 PM   #5
davitk's Avatar
Trade: Perfessional Contracter
Cut the planks out and put down plywood.
davitk is offline
Old 09-11-2009, 10:22 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Ply wood over the planks, then 1/4" denshield.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is online now
Old 09-11-2009, 10:23 PM   #7
angus242's Avatar
Trade: Tile
Enough said.
Good luck
Angus
The Following User Says Thank You to angus242 For This Useful Post:
reveivl (09-12-2009)
Old 09-11-2009, 10:36 PM   #8
Fentoozler
Celtic's Avatar
I don't know much about anything - ask anyone, they will tell you the same - but if your floor resembles this one in any way ~ I wouldn't put much faith in it:
A clean slate is so much easier to work with:
Celtic is offline
Old 09-11-2009, 10:50 PM   #9
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
you should be worried about deflection, it'll cost you when the customer calls you back to fix all the cracked grout.... every year...
Don't base you decisions on the condition of a tile floor in another room of the house. There could be much better support under that floor.
Forget using 1/4" plywood anywhere under a tile installation, it doesnt add any strength to the subfloor, and it's soft core can cause more trouble with deflection. Minimum 3/8" CCX plywood (BCX is better) for underlayment.
Next, cement board is not meant to add strength to the floor, it's just a compatible surface to adhere tile to. So building up two layers of 1/4" backerboard is not a smart idea.
It's usually not realistic to pull out the planks and replace with plywood. It adds a lot of time and materials to the project, especially since the planks always continue under interior walls, load bearing, and non-load bearing. If the customer is willing to spend the extra cash to save 3/4" in height, go for it.
99% of my customers have no problem living with the height difference. A marble or granite saddle in the doorway makes a nice transition and alerts peoples subconscious to the slight step up into the next room.
Go with 3/8" ply over the planks, Ditra membrane (1/8") and then tile.
- Alex
Long Island Remodeling Contractor
Splinter is offline
The Following 2 Users Say Thank You to Splinter For This Useful Post:
Celtic (09-11-2009), reveivl (09-12-2009)
Old 09-11-2009, 10:52 PM   #10
The Remodeler
Splinter's Avatar
Celtic- get some more screws into the field of that plywood, eh?
- Alex
Splinter is offline
Old 09-11-2009, 11:02 PM   #11
Fentoozler
Celtic's Avatar
Right now....there's mostly nothing under it
Not wanting to thread hijack [at least not yet ].....come visit me over here:
Butchered joists
Celtic is offline
Old 09-11-2009, 11:06 PM   #12
angus242's Avatar
Trade: Tile
1/2" EGP is the minimum underlayment. That's over a proper subfloor.
However, if your joists don't meet minimum deflection ratings for the type of tile to be installed, none of this matters.
You may not care. However, there are minimum requirements for a reason.
Angus
Old 09-11-2009, 11:08 PM   #13
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Yeah grout and stuff.
willworkforbeer is offline
Old 09-11-2009, 11:09 PM   #14
angus242's Avatar
Trade: Tile
and cracking tiles...
Angus
Old 09-12-2009, 08:27 AM   #15
Allow me to rephrase- The condition of the tile in the kitchen has me feeling comfortable with the JOIST deflection. The 12" tiles in that room butt up evenly against the same hardwood. That tile is over the exact same subfloor that is set on the same joists as the bathroom in question- it's all over an unfinished basement.
My original plan B was to cut out the planks and replace w/ 3/4" ply, but there wouldn't be joists to support the ends and there's way to much duct and knob-and-tube wiring to put more blocking between the joists to adequately support the edges of a new subfloor.
Alex, your plan sounds solid. Thanks for the constructive advice.
-Cliff
-Cliff
Old 09-12-2009, 09:00 AM   #16
davitk's Avatar
On second thought if you just caulk between the joists using Big Stretch, you should be fine.
davitk is offline
Old 09-12-2009, 12:14 PM   #17
angus242's Avatar
Trade: Tile
And how is that tile installed? My money is on a mortar bed
Look, do you want to do it right or just do it? Height is NOT what determines what is right. You've been given plenty of info to look at. You could do something goofy like 2 layer of 1/4" CBU or actually follow the recommendations of organizations that extensively test these methods.
What kind of installer do you want to be?
Angus
Old 09-13-2009, 12:07 AM   #18
-Cliff
Angus, did this not make clear "what kind of installer" I want to be?
Old 09-13-2009, 12:24 AM   #19
angus242's Avatar
Trade: Tile
Cliff, I'm not tryin to bust your balls but you keep replying and saying things that don't make sense if you want to do it right.
The TCNA says MINIMUM of 1/2" exterior-glued plywood. You said 3/8" sounds good.
The TCNA says MINIMUM deflection of L/360 for ceramic, L/720 for stone. You said you're not too worried about it and there's too much in the way to add blocking anyway.
You suggested the use of 2 layers of 1/4" CBU.....
I'm not making up the minimum requirements, I'm just stating what they are. You are the one who seems not interested in following them. If you spent $10 to get a copy of the TCNA Handbook, most of your tiling questions would be answered. All you have to do is follow the recommendations. IF you do that, then I'd say you're trying to do things right. If you choose not to, well then you tell me what kind of installer you're trying to be.
Angus
Floordude (09-13-2009)
Old 09-13-2009, 10:36 AM   #20
The Remodeler
Splinter's Avatar
Angus-
I'm not doubting the 1/2" plywood minimum, but I'd like to know where it says that... Can you quote from the TCA handbook?
This topic comes up regularly over at JohnBridge, and they recommend a minimum allowable underlayment of 3/8" for certain circumstances.
- Alex
Splinter is offline
ceramic tile on bouncy subfloor JohnHomeMatters Flooring 16 07-14-2009 09:19 PM
Removing Porcelain Tile on Stapled and Glued Subfloor ParaDiddle777 Flooring 20 11-08-2008 09:48 PM
Prepping a Plywood Subfloor for Tile After Demolition bluethumbnail Flooring 8 01-01-2008 09:47 AM
Wide Plank pine over plywood subfloor omenabay Flooring 1 11-12-2007 09:06 AM
