Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-25-2009, 02:36 AM   #1
Trade: Fire Suppression Equipment Sales & Service
Tile over Tile
I have a renter who has given notice and will soom be leaving the apartment. In the past he has parked his bicycle on the tile floor in the entry. The tires left black marks on the tile. His solution was to take a knife and scrape the black marks off. Of course now there are marks on the floor, and the tile need to be replaced. I do not have any of that tile, so the whole floor needs to be done, no patches. He wants to get some peel and stick to overlay the existing tile. The existing tile is tight to the floor. My very limited experience with the peel and stick was not good, the peel and stick did not stick. Is peel and stick stillcrap and just something a hack would use? Then of course there is still the trim that needs to be removed and installed, the issue of the tile not being flussh at the 4 doors. My preference, as a licensed contractor, is to just hire a licensed floor contractor to fix the floor.
I need some advice from the floor professionals.
Thanks in advance
fireguy is offline   Reply With Quote
Old 02-25-2009, 01:26 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Peel and stick get mixed results usually not good.
Install 1/4 underlay and new sheet Vinyl if you can take the extra height.
Floorwizard is offline   Reply With Quote
Old 02-25-2009, 01:32 PM   #3
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
What kind of tile is the existing? In todays market, "tile" is pretty vague.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
Old 02-26-2009, 11:36 PM   #4
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
If the only reason you're replacing the floor is because of metaql marks made on the tile, I know someone was talking about a product that can remove them now over at John Bridge's a couple of months ago. You might try going to the pros hangout and doing a search on metal marks.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Looking for porcelain tile that mimics slate hillblazer Flooring 8 02-28-2009 01:13 PM
Time for a new tile guy? orson Ceramic & Stone Tile 20 12-11-2008 08:38 PM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 06:44 AM
need input on tile job bford Introductions 1 09-24-2008 10:28 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
