05-08-2006, 01:56 PM
#1
Trade:
tilesetting
Tile over fireplace brick
Are there any special "needs" when tiling over a natural brick fireplace?
Thanks
Ronman39
05-08-2006, 03:17 PM
#2
Trade:
Residential custom home builder
I've thought of doing the same thing. I'd assume that if the brick is still solidly anchored you won't have any problems. You could always put cementboard on first to eliminate movement-related problems.
Clint - carpenter, coordinator, webmaster
05-08-2006, 03:30 PM
#3
Trade:
Remodeling
When we did it in our home, I'm pretty sure he built a 2x4 frame around the fireplace and put metal mesh up.
I'll ask him when he gets home.
Kristina
Originally Posted by Kristina
Dancing naked on a table in a bar is a "provocative act". Shooting a missile is liable to get your ass served.
05-08-2006, 10:42 PM
#4
Trade:
Renovations
I've done it straight to the brick, as said, if there are no signs of movement in the brick there should be no problem.
"Too much is always better than not enough"--J.R. "Bob" Dobbs
05-08-2006, 11:23 PM
#5
Chief Toilet Mover
Trade:
Bathroom Remodeling
Yep, right on the brick. However, I always try to do something 3d with a flat brick fire place instead of just tiling over it and creating a big flat thing. When doing that, you're going to end up tiling on Hardi or cement board.
Special considerations may involve using a ledger board to hold tile in place as it sets up or it might start sliding down the face as you put other courses on top of it, just like when doing a shower wall.
05-09-2006, 06:09 AM
#6
Tile Setter
Trade:
Ceramic Tile, Marble, & Stone
Here is another vote for tiling right to the brick.
- Bob
05-09-2006, 10:56 AM
#7
Trade:
tilesetting
any special prep to ensure longevity as it is a "hot" fireplace? I am thinking mortar and mesh.
Ronman39
05-26-2006, 03:39 PM
#8
red boots
Trade:
tile
I'm all for tiling right to the brick too, but after doing some research, found that the recommendation is to skim coat the brick with thinset first, because the brick and the mortar are going to absorb moisture at different rates and may possibly cause grout to crack or discolor.
05-26-2006, 03:50 PM
#9
Mod / ArchiBuilder
Trade:
Design/Build Construction
Ding Ding Ding, this is how I do it too.
05-27-2006, 09:02 AM
#10
Chief Toilet Mover
Trade:
Bathroom Remodeling
A skim coat first with thinset is a good idea, but I'm not sure how you are coming up with an issue with the grout. Unless you are back buttering the tiles, grout never comes in contact with the substrate on any tile job.
06-17-2008, 08:36 AM
#11
Trade:
Sanket
you need to setup brick frame over it.you have to make safe fireplace. No any other requirement
06-22-2008, 03:44 PM
#12
Trade:
Flooring Contractor, working to be a GC
xx
if the fp is tight, we skim with thinset and tile over!!
06-22-2008, 04:39 PM
#13
Tile Contractor
Trade:
Building Trades-Specializing in Ceramic Tile
Asked and answered more than two years ago.
06-22-2008, 05:21 PM
#14
Certified Remodeler
Trade:
Kitchen bath remodeler
Thinset and tile. I will be covering up my brick in the lower level, installing a gas fireplace (Central Fireplace) and then slate. Keeping the woodburner upstairs and I'm building a steel frame to make wider, thinset over existing brick and stone over the thinset and cement board on the steel framing.
08-19-2008, 01:19 PM
#15
Dmax Consulting
Trade:
Paint Contractor
I vote for dianna's solution
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
