Trade: house rentals
Tile Grout Color Too Light
My daughter bought a home with some cracked tile in the kitchen. I replaced eight tiles. I bought two bags of grout to try and match what was on the floor. I mixed a small portion, let it dry in a clump, and put it next to the existing grout and thought I had a match. Now the new grout I used is a shade lighter than old grout. Is there anything I can I do, to darken the grout, before I seal it, or do I have to scrape out the grout and do it over?
Thanks. |
celtic
Trade: Flooring
Re: Tile Grout Color Too Light
Most probably the original grout has darkened through age. Either that or you weren't lucky and got a shade difference. The chances of that not happening are remote so you will either live with it or take out the old grout and redo.
Trade: General Contractor, Remodeler
It's possible that the color you mixed was pretty good, but that while sponging off the top, you either used too much water and leached out some color, or that minerals in the water left a residue on top of the grout. If it's the latter, a vinegar wash (rinse well) will take off the residue and even out the color. Good luck!
Taranis, Thanks for the reply. When grout was wet, it was darker than original, of course. Is there an oil based spray I can use to darken grout and then spray sealer over that, to retain the darkened color?
Forry, Thanks. How do I cut the vinegar? Straight, 50-50?
celtic
Trade: Flooring
There are a number of different ways you can alter the colour. Everyone has there own way of doing it. You can wet - not soak - the existing grout then brush unmixed new grout over old. The old grout will take on some of the colour of the new then seal if you wish. Each way you do it will have it's own success rate dependant on how it's done and how old/contaminated the original grout is.
Try 50/50, if that doesn't work, you can dump it on straight and mop it up with a sponge. If it's been a couple of days, you can use a scrub brush and agitate a bit, just don't over scrub, you can damage the grout.
Re: Tile Grout Color Too Light![]() ![]() Oh, p.s. Use WHITE vinegar! Not red wine or apple cider or whatever!
Chief Toilet Mover
Trade: Bathroom Remodeling
You guys must know something I don't or I know something you don't.
![]() I've never heard of doing what you guys are proposing. New grout and old grout always are going to be different because of age, dirt, UV, the longer the time between the old and the new the better the chances of them not matching. There is only one guaranteed solution that I have ever been aware of: Aqua Mix Grout Colorant ![]() You will have to do the entire floor. |
#10 | |
celtic
Trade: Flooring
I think I said that earlier. These and the rest are tricks of the trade that have been known to work.
Thanks to all. This was my first post and I was apprehensive of asking a simple question of pros. I've read alot of other threads on many subjects and appreciate all the excellent input.
#12 | |
tile contractor
Re: Tile Grout Color Too LightQuote:
I don't care if you had the right color name, and even a perfect color match to the original grout batch. You're still going to see a difference due to aging. What Mike recommended is the only way to get it all to match, short of carving out ALL the grout and regrouting the entire floor, which is ridiculous. One other good thing about the colorant. Being that it's topical and epoxy based, not only will it permanenetly seal the grout, it'll also make it MUCH easier to keep clean! Now for the bad news-- those cracked tiles you replaced-- expect them to crack again, if you didn't find the cause of the cracking. The cracked tiles are just the symptom, not the problem, and until you find out where the cracking is coming from and alleviate the problem, it's going to keep happening.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com Last edited by Bill_Vincent; 11-26-2007 at 09:46 PM. |
Trade: Self employed - hard surface installer
I've been able to get new grout to match several times by mixing a slurry and blending it in over the old grout. Does not work in all situations , but if the older grout has not been sealed and you can stiff brush the joints good it works well.
tile mason
you'll go through 3 or 4 techniques 5 or 6 times
when you could just start and finish a grout colorant application in a day and as Bill stated, it seals the grout at the same time
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
If any one is applying a grout colorant to grout that was installed that same morning... well, I think it needs a little longer cure time than that. If the slurry doesn't work come back in a few days and then use the colorant...
tile contractor
I agree. Colorant shouldn't be used for a minimum of 3 days, and I'd much prefer to see a week. I don't agree with the slurry idea, though, only because of all the nightmares we've all heard about the grout turning out too light, or having a chalky look from being mixed too loose. I know you've used it, Jer, and I'm sure it worked for you, otherwise you wouldn't be supporting it. But it would make me nervous.
And What the heck are you doin up so early!! Only thing gets ME out of bed at 4:30 in the morning is FISHIN!!
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Jerry is silly like that Bill....that boy can't wait to get to work!
I can think of one other thing 'sides fishin that'll get me up that damn early. Wife ain't usually awake then though
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
#18 |
tile contractor
Read both our posts. I said gets me OUT OF BED-- not gets me UP!!
| Porcelain Floor Tile - fixing sanded grout cracks | ETHICS05 | Flooring | 11 | 07-18-2007 07:43 AM |
| Sealing ceramic floor tile grout? | kcrossley | Ceramic & Stone Tile | 6 | 04-16-2007 06:17 PM |
| Tile Grout for Masonry Joints | idfmason | Masonry | 2 | 03-30-2007 08:50 PM |
| No Grout Tile | KenTheHandyMan | Ceramic & Stone Tile | 8 | 09-23-2006 12:50 AM |
| Bad tile job | AAPaint | General Discussion | 9 | 07-26-2006 04:56 PM |
