Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-25-2005, 03:10 AM   #1
Trade:
Question thresholds/transitions
I have a few hardwood flooring questions dealing with molding around a uneven edged fireplace hearth and floor transitions. I am installing my customers prefinish 3/4" x 3 1/4" solid oak planks.
1) I am working on a creating a boarder around a fireplace hearth that has 3" high bricks with a rough front edge. Any ideas on how to improve over quarter round?
2) Current threshold & molding offerings seem easy to trip on (too high) and less than a perfect solution. Does anyone have a low profile threshold idea they want to share? The two surfaces are hardwood (3/4") & vinyl (1/2" plus or minus a 1/16").
Thanks in advance.
-E
elliott is offline   Reply With Quote
Old 02-25-2005, 03:28 AM   #2
Teetorbilt's Avatar
Around the fireplace, I'd profile and grout if it wasn't a floating floor, it's traditional brick to wood interface.
Transition mouldings I would make myself.
Teetorbilt is offline   Reply With Quote
Old 02-25-2005, 09:02 AM   #3
Don Benham's Avatar
Trade:
Send a message via AIM to Don Benham
How about undercutting the hearth with an undercut saw equipted with a masonry blade?
Don
Benham Flooring
__________________________________________
Look, I know the voices in my head aren't real, it's just that lately they've had some really good points.
Don Benham is offline   Reply With Quote
Old 02-25-2005, 01:36 PM   #4
Trade:
What Don said.
Anything else will look like a turd sandwich in addition to locking the floor in.
You can make due with a grider and diamond blade. You will need a second pair of hands to hold a vacuum next to your tool.
You might be able to rent a Crain 812 saw.That is what I use to undercut masonry. It is the cat's meow. has a vacuum port at the saw base. It is practiically dustless.
ccoffer is offline   Reply With Quote
