Thinset Under Backer Board?
Old 02-12-2006, 10:50 AM   #1
stringblade's Avatar
is it nessesary to spread thinset then lay backer board over it?
or is this only nessesary when your floor is out of level or has dips?
stringblade is offline
Old 02-12-2006, 11:00 AM   #2
R&D Tile's Avatar
Trade: Tile installations
Re: Thinset Under Backer Board?
Yes, it is needed, unmodified is fine for this, it's there to fill any voids, if the floor is out of level, this should be fixed after the board is down, thinset under the boards won't help there, the boards will follow any contour of the floor when screwed down.
Just to add, if you plan on doing any leveling of the floor prior to using a cbu, SLCs or any other poured products, CBUs shouldn't be installed over it.
You can use a SLC over plywood and tile directly over that and not use a CBU,
All CBUs have to be installed over plywood or OSB.
R&D Tile is offline
Old 02-12-2006, 11:11 AM   #3
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
This thinset under CBU seems to go around and around...
RD in your opinion is the thinset needed if the sub-floor is perfectly level and has no voids?
Mike Finley is offline
Old 02-12-2006, 11:22 AM   #4
R&D Tile's Avatar
You can't see or feel them, but they are there, you also void any warrantees, it's required by all CBU manufacturers.
Alot of consumers who have not used thinset under the boards have written in about cracked grout and loose tile over time, there is no going back once this happens to fix it, not worth taking a chance, unmodified thinset is cheap, only $7 a bag, it's not there to adhere the boards down, just to fill the voids, use Modified over them to set your tile.
Hope this all makes sense.
R&D Tile is offline
Old 02-12-2006, 12:05 PM   #5
Chief Toilet Mover
It makes sense, no doubt. I have just heard this debated so many times, wondered what you thought. If this was one of those "isn't required under all circumstances but if you do it every time you will never run into a problem type things."
Old 02-12-2006, 12:25 PM   #6
Zero Punch's Avatar
Trade: Floors and more
I've been bedding CBU with thinset for 15yrs and never had a problem, cheap insurance, we shoot it down with 1 1/4 roofing nails.
As far as thinset not really holding, we had one job where we did not get a change order and I had to remove 150 foot of durock. Not fun! Thank goodness for Milwaukee tools.
Zero Punch is offline
Old 02-12-2006, 12:59 PM   #7
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
There's a real easy way to end ALL debate-- read the manufacturer's recomendations. EVery manufacturer, without fail, states clearly that if the CBU is NOT bedded in thinset, all warranties are null and void.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Licensed & Insured bjg5240 Business 34 06-09-2009 07:56 PM
FlexBond Thinset chimney repair Steampiper Masonry 9 02-27-2009 12:40 PM
Transitioning drywall with cement board Lone Wrencher Drywall 19 03-02-2008 07:05 AM
can i use backer board for izote61 Flooring 2 08-19-2005 05:38 PM
Hardi Backer Board...??? dgrabs Flooring 10 05-11-2005 07:04 PM
