Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 04-17-2006, 12:03 PM   #1
Trade: Governmental
Theatre stage floor covering
We have a douglas fir floor on our theatre stage. The dept. head wants it covered with masonite and painted black. I'll get outside contractors to do it but would a flooring underlayment be better? Like Halex or a similiar brand? Any suggestions would be appreciated.
cycad is offline   Reply With Quote
Old 04-17-2006, 03:42 PM   #2
Tile Contractor
For what it's worth......
I have been involved in a few theatre stage floors in years past and they were always topped-out with a plywood underlayment product that had an "A" side. If this is a performance type stage that will see many chnages in scenery and the like then it will see a lot of paint and spills over time also.
The masonite is too hard and any fasteners used to install it will have the heads standing proud of the surface and will be seen by the audience. After painting, the fastener heads will also reflect light sources differently from the surface and stage-lighting will only intensify the problem.
That's my two cents anyway.
Bud Cline is offline   Reply With Quote
Old 04-17-2006, 04:13 PM   #3
Trade: Flooring
Send a message via Yahoo to Mike Costello
I think he should get the thespian grade plywood.
Mike Costello is offline   Reply With Quote
Old 04-17-2006, 04:17 PM   #4
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
C'mon now Mike, try to keep it clean. This is a family oriented forum
ron schenker is offline   Reply With Quote
Old 04-17-2006, 04:31 PM   #5
Trade: Flooring
I dont have a lithsp
Old 04-17-2006, 04:49 PM   #6
Tile Contractor
Yow but thespian-grade plywood is usually only available in San Francisco and it is................
WHOOPS! Nevermind, I was thinking of something else.
Carry-on.
Old 04-17-2006, 05:42 PM   #7
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
You guys are a riot lmao! cycad, Halex would work fine, use 7/8" staples, 2" apart on perimeter, 3" in the field.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
Old 04-17-2006, 06:23 PM   #8
adams,b's Avatar
Trade: hardwood floors
We put a 2 1/4" pine floor on a stage floor, it was aerobic, and sanded it down and screened it as if we were going to put finish on and they painted it flat black.....So my question is, how come you can't go in there and sand it down and paint it?
adams,b is offline   Reply With Quote
Old 04-21-2006, 10:00 PM   #9
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
I second Adam's idea. Though if they really wanted a plywood surface I certainly wouldn't staple it. Couldn't you screw it with flush screws a paint the whole thing with flat black?
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline   Reply With Quote
Old 04-21-2006, 11:50 PM   #10
Cpt. Chaos
Halex is a 5 ply 1/4" Birch Underlayment....Stapling is the right way to fasten it to the subfloor.
Precision Flooring
Old 04-24-2006, 07:29 PM   #11
Donedat's Avatar
Yeah but if you are using it for dancing and sliding and all the other stuff theatrical clubs do, then the staples will snag on the actor's feet or ballet slippers or socks.
Isn't there another product out there for this application?
Old 04-24-2006, 07:59 PM   #12
Cpt. Chaos
You use 1/4" crown 7/8" leg staples and if your gun is set up right they are countersunk I'm sure there are alot of products out there that will work as well or better, but the original post asked about it specifically. Halex' intended use is as an underlayment for resilient flooring.
Precision Flooring
ADA requirements for a stage 72chevy4x4 Construction 1 07-23-2007 09:14 PM
Is 3 stage heat needed? rakes9720 HVAC 0 03-05-2005 05:11 PM
American Standard Freedom 80 2 stage problem skooter HVAC 2 12-28-2004 06:57 AM
Heil Two Stage Furnace Not Working Unregistered HVAC 1 04-30-2004 05:35 AM
save 82% on a werner stage Grumpy General Discussion 4 01-22-2004 10:51 PM
