Trade: remodeling/specializing in kitchen & baths
Teak Flooring (interior)
meeting a decorator next wk and part of the project is setting teak floors on entire 1st floor. i imagine its carpet removel tack strip etc then install new. they have a sample of what they want (haven't seen)
i know that matl is extremly hard but can anybody offer any install tips/things to watch out for? |
Re: Teak Flooring (interior)
darn i'm just trying to keep this thread alive til i get some help
#1 would be aggressive dust control. Teak contains a lot of oil and will give you Brown Lung.
What is your subfloor?
Ruane Woodworks,LLC
Trade: Finish and Custom Trim
LOTS of saw blades, I think it is the silica in there.
No silica. The wrong speeds and feeds create the same problem as pine, sort of. The oils will burn and create a buildup on the teeth, in essence, making them 'dull'. There is a wax made for this, apply to the blade prior to cutting although I don't think that you will need it for a single flooring job.
The best advice is to start with some new, quality blades and build the price into the job. A good blade will run you $75-125 for 10". At the end of the day, dismount the blades and soak them in a shallow pan of mineral spirits overnight.
thanks. subfloor is probably 3/4" cdx but could be osb. any trouble fastening the floor w/ a standard mallet nailer?
Ruane Woodworks,LLC
lots of silica and resin. I have built many an outside bar and table set. It is killer on blades.
Teak is not really that hard. It's similar to Cherry in hardness. I've only sanded one teak floor. It was really soft as far as the drum sander was concerned. No need to use really rough grit on it. If it comes from a good mill, I would start out with 60 grit.
I admit...I don't know everything...but don't tell my kids I told you.
Where does this insistance on silica come from? Does sand make it through a trees system? I have never heard of such a thing and have been in the boat business for over 40 yrs.
#10 | ||
My custom title
Re: Teak Flooring (interior)Quote:
Benn Quote:
Ruane Woodworks,LLC
Re: Teak Flooring (interior) |
Moderator
Many types of plants contain silica. This article explains how it gets there.
Short answer is, its absorbed just like any other nutrient and if not expelled, then stored, usually in the cell wall. I guess like people, some plants will eat anything.
#13 | |
My custom title
Benn Quote:
unlicensed hack
Trade: wood butcher
I don't know all the facts about silica, but I know it is a very fine sand (mineral?). So theortically, it is prolly pulled up with water through the trees roots. I'm just thinking out loud here, but that makes sense to me that silica would be present in many plants, not just trees. Might be that teak trees thrive in that type of soil?
I also know that silica is used in the making of glass.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. |
I learn something new everytime I'm here.
That silica is what makes white oak heavier than red oak. The vessels in white are filled with silica. The vessels in red are empty.
#17 | |
#18 |
And red oak stinks to high heaven. Maybe silica is a good thing.
#19 | |
#20 |
We get a variety or oaks here. Water, Pin, Live and a few small species, I've never messed with any of them because I don't care for the look of oak. In NC, it makes good firewood but ringing, cutting and splitting still stinks as does the occasional piece that goes through my shop.
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| Hardwood Flooring - First Go at It | DecksEtc | Flooring | 56 | 10-05-2006 01:41 PM |
| Flooring in Log home | C.C.R. | Flooring | 7 | 09-05-2006 09:58 PM |
| Question about floating wood flooring | zoner11 | Flooring | 10 | 01-17-2006 05:04 PM |
| Re-claimed Vertical grain fir Flooring | Coop | Flooring | 5 | 11-13-2005 08:49 PM |
