Tarkett Laminate?
Old 06-29-2006, 11:26 PM   #1
cmejio's Avatar
Trade: flooring
Question
Tarkett Laminate?
hi, I was wondering if someone can tell me about the laminate from Tarkett. Any bad or good experiences? .... the problem is that I became very used to Quick-step, but I have a really good opportunity with Tarkett.... thanks
cmejio is offline
Old 06-29-2006, 11:38 PM   #2
Teetorbilt's Avatar
Re: Tarkett Laminate?
New one for me. Everybody seems to be jumping on the bandwagon.
Albert Einstein
Teetorbilt is offline
Old 07-04-2006, 02:47 PM   #3
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Tarkett makes a lower to middle of the road product. It is a direct pressure laminate with a rotating lock style joint system. It is pretty easy to work with, although you can't be as rough with it during install as say a Columbia or Armstrong product, or the tongues will snap off and create trash in the joint. It goes together just a little bit harder than Quick-Step.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Getting laminate under door casing and jambs Blackhawk Flooring 6 01-02-2008 04:14 PM
Granite Tile Countertops over Laminate c5150b Flooring 5 04-05-2007 11:57 PM
Miter Joints In Laminate Flooring ?? AL MURZYN Flooring 6 12-27-2006 10:15 PM
Laminate Floor Richard Flooring 15 12-22-2006 12:59 PM
Tile or Laminate jwaldman97 Flooring 15 10-14-2006 06:41 AM
