Tar Paper
Old 03-04-2008, 10:49 PM   #21
fast pasquale's Avatar
Trade: Hardwood flooring contractor
Re: Tar Paper
You should stick to masonry.
Chris Frate
Pasquale Floors
fast pasquale is offline
Old 03-05-2008, 10:13 AM   #22
Angel241's Avatar
Re: Tar Paper
Thanks for the links oldfrt - I think the trick with this is to not take too much off, just enough to preserve a bit of the dirt in the little knicks and such, to give it that old look.
We are really on the fence at this point as to what we are going to do with the finish. He's dead set on a satin finish, while I'd rather have a semi-gloss. I think putting satin on floors is a huge mistake - shows too much dust/dirt.
Angel241 is offline
Old 03-05-2008, 10:56 AM   #23
Re: Tar Paper
Gloss/semi gloss with bring out all the imprefections. Satin will hide all the imperfections. You got it backwards
Chris Frate
Pasquale Floors
Old 03-05-2008, 12:21 PM   #24
Angel241's Avatar
Re: Tar Paper
I didn't mean the imperfections in the floor, but the dirt/dust that collects on the floor after it's been finished. We did a couple of other rooms in the house using a satin finish, and it shows every speck of dust that collects onto it, worse than all the other hardwood floors I've dealt with.
If I'm wrong, though, let me know.
Angel241 is offline
Old 03-05-2008, 02:17 PM   #25
Re: Tar Paper
You are.. and I did..haha Good luck.
Chris Frate
Pasquale Floors
Old 03-05-2008, 02:28 PM   #26
Angel241's Avatar
Re: Tar Paper
Ok!
Angel241 is offline
Old 03-06-2008, 01:32 PM   #27
THE FINISHER
lawndart's Avatar
Trade: Finish Carpenter
Send a message via AIM to lawndart
Re: Tar Paper
Angel,
From my experience, using a semi gloss will show more surface scratches than a satin finish, but looks much nicer when new. The darker the stain the more dust you will see, and the lighter, the more dirt. Most hardwood flooring guys would agree with me.
lawndart is offline
Old 03-06-2008, 01:53 PM   #28
Re: Tar Paper
Im with lawndart on this one. Go with the finish and gloss you like. Not b/c it'll hide the fact that you don't ever clean your floors. haha. There is a huge diffrence between the look of satin and gloss. Figure out what you like and dewit!
Chris Frate
Pasquale Floors
Old 03-06-2008, 02:23 PM   #29
Suck it up, or shut up
rservices's Avatar
Re: Tar Paper
I had the exact same stuff on my 100 yr old home, I used a heat gun and a scraper. once I got about 90% of it off I sanded. The room is about 12 x 12 and it took over 20 hours.
Was it worth it YES, great maple floor.
I had the same in the kitchen but the floor was damaged so I tiled
rservices is offline
Old 03-07-2008, 02:00 PM   #30
Angel241's Avatar
Re: Tar Paper
Thanks for the insight on the different finishes on the floors. I'm not so much trying to hide the fact that I don't clean the floors It's more because we still have a lot of drywall dust in the air.
We're going to be going to pick up the sander again, as well as the edger. I'm trying to gauge out how much of the finer grit paper I'm going to need. About how long, in theory, should a 60, 80, 100 grit sheet last?
rservices, it's amazing you were able to get it off with a heat gun. For us, any kind of heat just melted the tar into the wood worse making it a gooey mess.
Angel241 is offline
Old 03-07-2008, 03:25 PM   #31
Re: Tar Paper
Well this isn't the standard floor. If it were.. each sheet should last approx 600 sq feet.
For this application with the adhesive still there... maybe 300sq feet at the most. You'll just have to keep checking the paper.
One trick is to use the flip the paper over and use the other side.
Chris Frate
Pasquale Floors
Old 03-08-2008, 06:06 PM   #32
Angel241's Avatar
Re: Tar Paper
So we got the floors done with the rough grit sandpaper today. They look soooooo much better already!
Tomorrow will be the fine grit paper as well as the edger.
It turns out that one spot that I loved the grain in so much isn't original. There's about three boards there that had been replaced, and we think it marks where the hallway before the old classroom had been.
There's a few spots of tar that I don't think we'll be able to get up due to the floor being as wavy as it is.
The 24 grit paper made a huge difference today in going through the tar on the floor. For all of it, I think we only ran through 5 sheets of it.
Angel241 is offline
Old 03-17-2008, 04:50 PM   #33
Angel241's Avatar
Re: Tar Paper
Okay, so now that we're getting closer to finishing up the rest of the stuff in the living room, I figured I would start looking into what we really want to do with the floor.
What finish would you recommend most, and what brand do you prefer? We really want to do this right.
Angel241 is offline
Old 03-17-2008, 08:27 PM   #34
Administrator
Nathan's Avatar
Trade: Admin
Re: Tar Paper
Originally Posted by AtlanticWBConst View Post
Hi, you might want to post your experience over at the DIY Chatroom.
As a Home Owner, you would have alot of other DIYers interested in seeing the progress you are making, as well as your experience in refinishing your floor.
Yea, DIYChatroom.com might be the best place for this. Thanks.
Nathan
"He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot
Nathan is offline
Old 03-17-2008, 10:10 PM   #35
Handle It!
MALCO.New.York's Avatar
Re: Tar Paper
And please, please, please do not "Over finish" the floor. Do not sand it "new". Leave some age so it remains what it is. Character is as important in an old house as much as function is.
Ultimate Wisdom---------
MALCO.New.York is online now
Old 03-17-2008, 11:28 PM   #36
Re: Tar Paper
Sorry.. I diagree.. Sand it down to the bare wood.. get it clean as possible and finish it.
This is not 125 yr old heart pine where you want to keep its character...Its doug fir/pine...
Chris Frate
Pasquale Floors
Old 03-18-2008, 12:25 AM   #37
Handle It!
Re: Tar Paper
This is what opinions are for. But then again I do not do floors.....
Old 03-19-2008, 11:45 PM   #38
72chevy4x4's Avatar
Re: Tar Paper
what's up with the influx of DIY questions? Seems like March is the month for HO's to sign up and get their questions answered.
72chevy4x4 is online now
Old 03-20-2008, 12:45 AM   #39
Moderator
Double-A's Avatar
Re: Tar Paper
Angel has been on the forum since March of 2005. Things were a bit more lax then.
Nathan has said his peace and I think he's content with it.
I think the DIY'er coming out in March in general is the same reason we have so much traffic right now from the contractors. We're all suffering from Cabin Fever!
New York Times, July 20, 2006
Double-A is offline
Old 03-20-2008, 12:51 AM   #40
Re: Tar Paper
It's all good.. Mostly the big plank 100+yr old stable old growth trees keep the patina nice.. Then it's just a quick clean.. minor abrasion and maybe some tung oil/penetrating finish works nicely.
Chris Frate
Pasquale Floors
Type of Paper Under Hardwood CharlieDaw Flooring 2 04-12-2007 10:43 PM
Wood Floor and Rosin Paper over Radiant cyepsen Flooring 2 03-08-2007 09:50 PM
Paper Adhesive tape. jstrand23 Drywall 1 03-07-2007 06:02 PM
commercial wall paper removal rservices Wallpaper 1 06-28-2006 09:58 PM
why primer is bubbling up over wall paper Zeebo Painting & Finish Work 2 07-10-2005 10:11 PM
