Unregistered
Guest
Posts: n/a
Tactesse Carpet & Quality
Has anyone had any experience with the wearability of nylon tactesse carpets? One installer says the denier of the fibers are finer to make the carpet softer and it wears out quickly. Also, what is the minimum density, twist and weight a carpet should be?
Re: Tactesse Carpet & Quality
Over all I have noy had one complaint on that rug and I have installed a coupla miles of it ( our salesguy loves it.) It is a great bedroom carpet as it is very soft.
As far as minimum wieght and density that is pretty much a price point ,so you have to ask yourself where you need to be pricewise and get the best you can afford. As far as twist goes ,in my opinion that is an asthetic thing. The heavier ,or more, the twist,the less you will see footprints. |
Flooring Guru
Trade: Sales Manager
A soft yarn is no different in durability as a hard yarn of equal twist and density. That has been proven.
Half of all high end carpets are soft yarn now.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Trade: Flooring
Nylon Tactesse carpet is a stronger, much softer form of nylon. Nylon tactesse contains smaller, more densely packed fibers that create a softer feel while at the same time being much more durable. If you can afford the added price of nylon tactesse we highly recommend it. A carpet containing nylon tactesse will retain its texture longer than a standard nylon carpet.
#5 | |
Its all ball bearings
Trade: Tile
Re: Tactesse Carpet & QualityQuote:
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Flooring Installer
Trade: flooring
Probably pushing it because he sells it.
Flooring installer since 1973 Armstrong certified |
| tips on painting baseboards with carpet floor and a tip for new painters | Zeebo | Painting & Finish Work | 10 | 04-22-2011 06:42 PM |
| Baseboard trim before or after carpet | mtheisen0814 | General Discussion | 19 | 05-28-2008 09:58 PM |
| Moldings Quality | VA Remodeler | Finish Carpentry | 6 | 08-16-2007 09:40 AM |
| New to carpet tile | J&J Home Imp. | Flooring | 7 | 06-22-2007 07:05 PM |
| Carpet and hardwood | J DoubleD FLoor | Flooring | 7 | 09-16-2006 02:03 PM |
