Recovering IT Guy
Trade: Handyman, Home Improvement, Kitchen & Bath Remodeling
Subfloor Requirements
I removed some 5/8" plywood with vinyl flooring attached to it. The subfloor under that is 11.25" x 13/16" T&G. Is the ~7/8 T&G sufficient to carry the new 3/4" hardwood floor, or do I need plywood on top of the T&G?
Second Look home improvement www.SecondLookHome.com Handyman and Home Repair Specialist in Rhode Island RI Licensed Lead Safe Remodeler/Renovator, RI Registered & Insured Contractor |
Trade: Building/Remodeling
Re: Subfloor Requirements
Is the T&G sub in good shape, I have always found that t&g subfloors are not as smooth and flat as I would want so I typicaly nail and glue 1/2 over it to keep the HW from any possible movement. The thickness isnt an issue (13/16) but if there is a wavyness on the surface it will cause problems down the road. Also CDX plywood holds flooring nails better than pine. Of course this is just my opinion, but check with the manufacturer to be safe.
Recovering IT Guy
Do you think 1/4" would help, or is 1/2" really the way to go? I am a little concerned about waviness, especially since this is a low-cost Bruce hardwood where there are lots of small pieces.
Recovering IT Guy
Does anyone have feedback on this? I would like to get some 1/4", glue and nail it over the 7/8 T&G then put the hardwood over that. It's easier to work with 1/4" than 1/2", plus the ceilings are a little low.
Trade: Finish carpenter
If the T&G is wavy 1/4" ply will mask it temporarily,1/2" would be a lot better,if there's an issue about the height have you considered sanding out the waviness.I've done this in the past and it's worked out well.
Home Improvement Guy
Trade: Renovations contractor
I'm surprised the vinyl had 5/8" under it? That seems like overkill? Or am I missing something?
Don't worry, the baseboard will hide it! |
#7 | |
Recovering IT Guy
Re: Subfloor RequirementsQuote:
The T&G isn't wavy, but the Bruce hardwood we're using has some pretty short pieces and I want to make sure the hardwood has a firm smooth underlayment. Will be using 1/4".
