Subfloor Recommendation For Ceramic
Old 10-02-2006, 09:37 PM   #1
72chevy4x4's Avatar
I have a small bathroom, 4x6, which has a 3/4" subfloor (particle board). Before laying the cmu, should a 1/2" layer of plywood go down to build up to 5/4" ?
72chevy4x4 is offline
Old 10-03-2006, 05:27 PM   #2
R&D Tile's Avatar
Trade: Tile installations
Re: Subfloor Recommendation For Ceramic
Particle board or OSB?, if particle board, it has to come up.
R&D Tile is offline
Old 10-03-2006, 07:04 PM   #3
tile mason
MattCoops's Avatar
It's probably most likely not particle board
you probably have chip board which some people call particle board for some reason
you can trowel thin-set and screw wonderboard over subfloor
and tile over that
MattCoops is offline
Old 10-03-2006, 09:05 PM   #4
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
I know you need at least 1"1/4 sub-floor before cmu. Plywood over OSB? I cannot say yes or no.
If it is real particle board like that stuff they put down in the 80's I'd tear it out...then go back with ply.
Looks like some pros were here.
Gordo is offline
Old 10-03-2006, 09:26 PM   #5
72chevy4x4's Avatar
my bad, it is osb. I ended up putting down a layer of thinset, then screwing down duroc.
A side question concerning the tile work: because of the dimensions and variety of tile sizes, I made the joints going one direction slightly larger then the other direction (so as not to have a thin tile piece at the wall). The tiles ranged in size from 14" square, 7x14 and 7" square. Is there potential for failure in joints (cracking maybe) from being too large? The size wasn't riduculous-just 1/8" larger than what I had been using in the other direction.
Old 10-03-2006, 09:34 PM   #6
reveivl's Avatar
Trade: Renovations
Sanded grout? How big are the joints?
reveivl is offline
