#21 |
Trade: Commerical Construction
Re: Subfloor Over Concrete For Hardwood
Sika have changed the installation instructions to say not to be used with soild hardwood.
The T55 remains flexible but the T53 dries ridged. a major job that used an engineered flooring also failed as the engineered floor was not stable and had to much movement. the system works great when used with 3/4 ply & then hardwood. |
#22 |
ian @antex western
Trade: flooring
hi mrghm,
I have looked again at the spec sheet and they all say for use with solid & engineered woods, we have a Sika factory on the next block and i have spoken to them again & also attened a training/info session with them on these adhesives some months ago as well as using them myself in the past,and never had this problem. we also have a part laid floor sample on display (made up six months ago) the adhesives when cured are still flexible even now, sounds like you may have had a bad tub or two, as laying over 3/4 ply instead of concrete should not make any differance with how the adhesive sets, ie ridged/flexible. the adhesive should curl the same on either surface.
| Concrete Strength | Gnanchandra | Construction | 3 | 12-24-2008 09:19 PM |
| Concrete stain problem | Forry | Concrete & Paving | 6 | 09-02-2008 09:10 PM |
| Advice - concrete Pool Deck coping | ejleonard | Masonry | 4 | 06-17-2008 05:18 PM |
