Sub-flooring For Sheet Goods
Old 05-18-2007, 08:21 PM   #1
TRISTAN's Avatar
Trade: REMODELER
I'm Faced With A 1955 House With A Tile Floor Layed On 1/2 Inch Plywood That Is Now Rotted In Places And Scared From Trying To Remove All The Adhesive. Should I Just Replace The Sub Floor, And If So, Put Plywood Or Another Type Sub Floor Material. New Floor Will Be A Sheet Good Product. If I Just Patch Rotted Spots Should I Use A Leveler Prior To Installing The New Floor?
TRISTAN is offline
Old 05-18-2007, 08:53 PM   #2
seamerdeamer's Avatar
Trade: Flooring Installer
Send a message via MSN to seamerdeamer
Re: Sub-flooring For Sheet Goods
I would replace all the plywood that is rotten once you remove the rotten spots then you will be able to see if the joists are rotten as well if they are, they would need attention too. Do you know what caused the plywood to rot? once thats resolved and fixed I would lay 1/4'' underlay on top of the 1/2'' I use 1 5/8" diversion staples to fasten the underlay , in the seams every 2" and every 4" in the field.Then patch the underlay seams with polymer modified patching compound then your ready to lay the new sheet good.
seamerdeamer is offline
Old 05-18-2007, 10:03 PM   #3
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
I will agree with all of that except patching the joints of underlayment. Sanding them is a better option imo. Patching actually promotes telegraphing in sheet goods. As the floor expands and contracts the patch breaks up and forms a ridge, showing the seam.
I use Halex or Multiply. Both are a 5 ply baltic birch panel, available in either 4X5 or 4X4 sheets. I prefer 4X5 myself, it is easier to offset your joints from the get go.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 05-19-2007, 12:08 AM   #4
TRISTAN's Avatar
Trade: REMODELER
Thanks Guys, It's A Small Job,probably Just One Seam So I'll Just Sand And Go
THE JOISTS LOOK GOOD SEAMDREAMER THANKS FOR THE HEADS UP
TRISTAN is offline
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
Hardwood Flooring For Large Projects StonewoodSP Marketing & Sales 1 12-08-2005 09:38 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
Laminate Flooring Gina Flooring 9 04-28-2004 12:06 AM
