Strand Woven Bamboo
Old 10-13-2011, 05:57 PM   #1
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,850
Strand Woven Bamboo
I am installing strand woven bamboo for the first time. Any tips on cutting and best fastening practice.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
Old 10-13-2011, 11:36 PM   #2
ernesto's Avatar
Trade: Licensed Contractor in AZ
Rewards Points: 150
Re: Strand Woven Bamboo
The shyt is hard, use a new blade and 18 ga cleat nailer. I'm going in on an 1100 sf 5/8 gluedown on concrete next week. I pray alot.
Top Floor Installation Co.
Tucson AZ
www.tucsonazflooring.com
http://www.floorsavior.com
ernesto is offline
The Following User Says Thank You to ernesto For This Useful Post:
TNTSERVICES (10-13-2011)
Old 10-13-2011, 11:40 PM   #3
Hair Splitter
Trade: General
100 tooth? PSI for 18ga?
Old 10-13-2011, 11:44 PM   #4
ernesto's Avatar
Rewards Points: 150
60-80 carbide tooth will do but the PSI depends on your nailer and compressor. Practice first
Tucson AZ
ernesto is offline
Old 10-13-2011, 11:49 PM   #5
Hair Splitter
Trade: General
Thank you! Anyone else have input?
Old 10-14-2011, 06:52 AM   #6
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,133
You should have gotten a floating type with a locking system. A good blade is a must. This stuff is about twice as hard as oak and will kill a blade very quickly. Nailing is very tricky. You have to have the right nailer for it to start with. It isn't 3/4" thick like traditional floors so a regular flooring nailer will not line up correctly. Even with the correct nailer there is a good chance you will split the product when you staple or nail it. I've seen several installer have to resort to predrilling the product before nailing, which is insane. We only use locking strand products now.
gideond is offline
The Following User Says Thank You to gideond For This Useful Post:
scraigc (11-04-2011)
Old 10-14-2011, 06:56 AM   #7
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Bamboo is not as complicated as teak in my opinion. We install alot of both and always prefer the bamboo. At least the bamboo comes straight. Why not just use your flooring nailer.
ohiohomedoctor is offline
Old 10-14-2011, 08:35 AM   #8
Hair Splitter
Trade: General
I am def going to try the nailer route first. As far as I can tell it's more like 3 times harder than Oak. The back of the sample states a 3944 hardness rating. I think oak is less than 1300. It's going to be a challenging job. I first have to rip out oak. Their dogs killed it.
Old 10-14-2011, 08:50 AM   #9
Talking Head
EthanB's Avatar
Rewards Points: 14
Wear good quality hearing protection. The cuts are going to be really loud.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Old 12-12-2011, 10:38 PM   #10
Floors San Francisco
hawaii's Avatar
Trade: Flooring
Rewards Points: 75
I think this flooring has so much glue or some kind of plastic that the wood blades will burn it not cut it. I have bought $100 new blade and it would burn it it.
This is why this flooring is so hard is has more glue in it then wood, or grass because bamboo is not wood, plus it is all compressed.
Make sure you are using the right gun, and the right gauge of the cleats, some bamboo needs to be fastend by thin cleats otherwise it the thick cleats will create minimal bumps on the seams of the floorboards that are very hard to see, not possible to see it unless you nail the next board and look against the light.It can look pretty good and when the whole floor is installed , you look against the light and see this minimal bumps on the seams.
You can glue it down but it is a job for pro, glueing is pretty challenging if you do not know what you are doing.
Da Vinci Floors surfing and sanding.
Honolulu Hardwood Floors San Francisco I Hardwood Floors Hawaii
hawaii is offline
Old 12-13-2011, 01:23 AM   #11
Hair Splitter
Trade: General
All 1100 sq feet are in. Looks great.
Used my Bosch 4100DG table saw and my Bosch 3912 miter saw.
Didn't have much of a hard time cutting until the end when the blades began to dull. But even then it cut nice, just a little slower.
Old 12-13-2011, 02:56 AM   #12
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
Looks like it turned out great, well done!
How long did it take you?
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
Old 12-13-2011, 09:45 AM   #13
Hair Splitter
Trade: General
On the downstairs we did 800 sq ft. We had to demo the oak in the Kitchen, hall, bath, and foyer and carpet in the family. It took 3 days to demo and prep with 2 guys and 3 days to install and trim out
The upstairs was only 300 sq ft, but had a lot more cuts and corners. It only took 1/2 a day to pull the carpet and prep the floor. Gotta love these high priced slapped together homes. We had to repair the floor at the top of the stairs. The joist was waned, so instead of sistering some 2x they just screwed the sub floor down and filled with floor leveler. And a bad job at that.
So we pulled it up and fixed it. We also found half a sheet not even nailed down.
Probably the biggest pain in the rear was trying to get register vents and 1/4 round to match the bamboo. Thank God for my guy at Ben Moore, he can match anything dead on.
The Following User Says Thank You to TNTSERVICES For This Useful Post:
moorewarner (12-13-2011)
Old 12-13-2011, 09:45 AM   #14
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 512
What did you end up going with for the fastening?
I'm a fan of the different widths, I think it helped add a bit of character to the floor. Were you able to swing the inset hvac grates in the living areas, or did they stick with those metal ones throughout?
I hate to nit pick it, so other than the stepped and stacked joints, I do like the job!
KnottyWoodwork is offline
Old 12-13-2011, 10:34 AM   #15
Hair Splitter
Trade: General
I couldn't inset, I used oak for the downstairs and threw the metal back in the closet.
The biggest issue was that all the boards were 3' in length. I had to get creative. The CU had purchased the material long before hiring anyone, so I got stuck with what they had.
I ended up using 1 3/4" cleats and a PowerNailer 45. Set it to 110 PSI with a 5.4cmf compressor. Worked like a charm! No issues what so ever with the cleats going in or splintering.
KnottyWoodwork (12-13-2011)
Bamboo questions McKeeFlooring Flooring 4 10-11-2011 08:19 PM
Trillium bamboo KG007 Flooring 6 09-06-2011 10:48 AM
Bamboo flooring from China-bubble up failure joebuilderinc Flooring 10 08-09-2009 07:10 PM
Bamboo on stairs with warped stringers tgeliot Flooring 6 11-02-2008 12:35 PM
