Stauf 960 Adhesive
Old 10-23-2009, 05:24 PM   #1
cprao's Avatar
Trade: potential contractor
Stauf 960 Adhesive
I am researching for one my customer who has purchased Patagonian Rosewood for his flooring. This is a engnieered wood. The shop where he brough the wood recommends him to use Stauf 960 since it is glue and vapor absorver. I have never used this material before.. So looking for the ideas like - Is it really good ? If yes, how expensive it would be ?
Your thoughts ?
cprao is offline
Old 10-23-2009, 07:45 PM   #2
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Re: Stauf 960 Adhesive
Its really good and really expensive!!
the big 12 inch is offline
Old 10-23-2009, 08:09 PM   #3
Knowledge Factory
Floordude's Avatar
Use the recommended trowel!!!
http://www.AustinFloorguy.com
Floordude is offline
Old 10-24-2009, 02:11 AM   #4
cprao's Avatar
Any idea why it is so expensive ? Does it really act as a water vaporizer and glue ? How much I would need for 700 Sq ft area ? Any one used this material before ?
cprao is offline
Old 10-24-2009, 09:21 AM   #5
Knowledge Factory
Floordude's Avatar
The spread rate averages 35-45 sq.ft. per gallon.
Old 10-24-2009, 10:23 AM   #6
cprao's Avatar
Any other alternatives to this stauff 960 that has both moisture barrier and glue ?
cprao is offline
Old 10-25-2009, 10:13 AM   #7
Knowledge Factory
Floordude's Avatar
They are the only one marketing there adhesive, as a one application adhesive and moisture barrier.
960 is all marketing, as I have seen it not suppress slightly high moisture emissions.
Old 10-25-2009, 04:46 PM   #8
cprao's Avatar
Thank you !!
cprao is offline
Verdict on drywall adhesive vs. screws d's Drywall 46 09-15-2009 12:07 AM
What is the best way to remove V-31 adhesive from a new floor? geospec Flooring 5 09-13-2009 12:22 AM
VCT Adhesive Failure dmranney Flooring 2 12-31-2008 09:53 PM
Composite trim and adhesive questions JLTrim Finish Carpentry 4 10-12-2008 04:55 PM
Good trim adhesive? banctecbobn Finish Carpentry 16 09-18-2008 07:24 AM
