Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-10-2009, 01:46 PM   #1
JonM's Avatar
Staple Recommendation
What size staple is recommended for this 1/2" floor?...and will a pneumatic flooring nailer penetrate the hard Brazilian wood without any trouble? Sub is 5/8 ply...
http://www.lumberliquidators.com/cat...productId=6589
JonM is offline   Reply With Quote
Old 02-10-2009, 07:34 PM   #2
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
1-1/4 or 1-1/2" should get you through the subfloor...Which should be at least 3/4" ply or OSB...Good luck!!
the big 12 inch is offline   Reply With Quote
Old 02-10-2009, 08:53 PM   #3
first of all the subfloor is not going to be supportive enough IMO. also thats a engineered wood so its only a few MM thick of the actual tigerwood, so the stapler isn't going to have an issue. most flooring staplers are 1" and they are remmended for 1/2 floors so a 1" with the proper stapler should be fine.
however, i am more concerned about subfloor then the stapler/staple. i would glue and screw another 1/2" layer of ply over the existing.
again this is just my opinion. good luck
BSA Renovations - Restoration and Renovation Specialists serving Maryland's Frederick, Carroll, and Howard Counties
s. donato is offline   Reply With Quote
Old 02-11-2009, 06:15 AM   #4
With only a 1/2" flooring, I will third the add another layer of subfloor.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline   Reply With Quote
Old 02-11-2009, 07:43 AM   #5
JonM's Avatar
If I add another 1/2 inch ply then the 1/2 inch flooring it will screw up all the thresholds leading to the other rooms...(marble leading to the bath, carpet in 1 bedroom, and adds an inch to the top step)
Old 02-11-2009, 08:17 AM   #6
Even though the 5/8 is a little thin you can probably get by with it...I have done it a few times over the years...I would make sure the subfloor is screwed down tight and lay the floor against the joists if possible...
Old 02-11-2009, 09:55 AM   #7
what is the use of the room? you say bathroom so i assume second floor bedroom or similar?
12 inch is probably right you can get by with it laid perpendicular to the joists but if its a first floor living space that parties could potentially be an issue - redo your thresholds. it may be easier then worrying about the flooring coming apart in a couple of months.
as for for steps if they are carpeted pull the carpet back on the top three steps then add spacers to the steps to build up those steps gradually so your one inch gets absorbed you may have to add some carpet to the top riser when the carpet is reinstalled. if the steps are wood then your screwed ;-)
honestly i think its less of an issue about the subfloor being strong enough i would worry more about the flooring not lasting. i would try to talk the HO into a 3/4 solid wood so that there is no need to do anythign with the subfloor. you will have better control then and would probably never run into an issue.
one thing i would do is with what ever you choose mark all your joists and try your best to get the seems in the traffic areas to fall on the joists so you don't have week spots in the floor think about the squeking down the road.
Old 02-11-2009, 12:45 PM   #8
JonM's Avatar
The place I will be installing the floor is in a condo on the third floor bedroom and hallway...garage on the first floor and kitchen and living room on the second. Their are no children, just a single women who weighs in at about 110...I had already planed on securing the sub floor with screws, as the floor squeaks. I also am going to lay the floor perpendicular to the 2 x 10 16 oc joists. It's to late to suggest 3/4" flooring as the flooring has been ordered already.
My question is (see photo) I have access to two guns, one shoots a 1" 21 gauge staple and the other one shoots a 15 gauge 2" (shown below) staple. The smaller one seems to not penetrate deep enough and the other one seems like it might tear up the flooring while installing it...what are your thoughts here?
Old 02-11-2009, 02:07 PM   #9
Trade: Framing
That doesn't look like a flooring stapler, is it?
fixitpete is offline   Reply With Quote
Old 02-11-2009, 03:29 PM   #10
JonM's Avatar
If you are refering to the smaller stapler...Yes it is...
http://www.bostitch.com/default.asp?...2&TYPE=PRODUCT
Old 02-11-2009, 04:06 PM   #11
the big one you could probably get a 1-1/2" staple for it. i have used the 1-1/2" in my bostich flooring stapler MIIIS
http://www.amazon.com/exec/obidos/AS.../sdonatocom-20
i found that you need to add some material to make the shoe fit the flooring right. but you really need a different gun b/c the 15ga is really too big.
if i use a different nailer - i will only use 18ga flooring nailers not the 21 ga.
i think you need this one http://www.amazon.com/exec/obidos/AS.../sdonatocom-20
Old 02-11-2009, 04:30 PM   #12
JonM's Avatar
I was afraid of that...but I think instead of buying a new gun for 300 buck...I do own one of these... http://www.amazon.com/Bostitch-SX150...4388154&sr=1-2 It takes an 1 1/2" staple and the area I have to do is only 330 square feet...Think it could be done?
Old 02-11-2009, 08:15 PM   #13
Knowledge Factory
Floordude's Avatar
This is funny!!
Has anyone clicked on the link to the flooring??
That is a floating only clic lock floor. Don't even try to fasten it down!!
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
Old 02-11-2009, 08:47 PM   #14
Trade: Flooring
Send a message via Yahoo to Mike Costello
Nope, just an engineered , can be nailed or glued
Id use my Powernail e cleats
Mike Costello is offline   Reply With Quote
Old 02-11-2009, 10:19 PM   #15
Trade: Framing
  • Brand: Schön
  • SKU: DURENBK5
  • Finish Warranty: 30 years
  • Trade Name: Muiracatiara
  • Botanical Name: N/A
  • Janka Rating: 2160
  • Width: 5"
  • Thickness: 1/2"
  • Construction: Engineered
  • Installation Type: Nail/Glue
  • Sq. Ft. Per Box: 46.59
  • Hardness Rating: N/A
  • Waste: 10%
Old 02-12-2009, 08:12 AM   #16
I use this for 1/2 and 3/8"...$200 brand new...it will be a major pain trying to use your 90 degree stapler...you'll see!!!
Old 02-12-2009, 09:07 AM   #17
JonM's Avatar
What is it?
Old 02-12-2009, 09:42 AM   #18
90 degree stapler will be a PITA.
since its a small job why not just rent one of the ones 12 inch or i suggested?
but the specs on your stapler say its for upto 1/2 so technically you should be okay. would i use that stapler? no but its your job so if you think its secure enough move on to the next one.
one thing you could look at is - you could always glue the T&G and/or add some glue to the subfloor as you go. the good thing is you will not need to clamp it since you are stapling it to. just an idea.
Old 02-12-2009, 10:37 AM   #19
JonM's Avatar
Actually I did take your advise and bought the Bostitch SX150-BHF-2...When it came down to it, my professionalism overcame my frugalness......hey, you can't have enough tools...correct...thanks again for the help....and the guy at my local tool store gave it to me for the same price as Amazon...
Old 02-12-2009, 04:49 PM   #20
Trade: Flooring
What is it?
Mannington Monster gun, made by Spotnails
Chipping Hammer Recommendation Kene_kj Tools & Equipment 3 01-20-2009 09:52 PM
Looking for a product recommendation tom m Flooring 11 10-29-2008 09:52 PM
Color recommendation mdshunk Painting & Finish Work 19 10-21-2008 07:57 PM
tailgate lift recommendation? 31b Vehicles 2 09-25-2008 12:11 PM
