Stain Won't Dry!!!
Old 01-13-2008, 01:16 AM   #1
downwithfloors's Avatar
Trade: Hardwood flooring
Stain Won't Dry!!!
I have just applied three (yes, three) coats of oil based stain on 1000 square feet of freshly sanded oak that's not absorbing it. It's been drying for almost 2 days and it's still tacky. I can't crack a window or door in the room, and I'm at a loss. I have never had this happen before. Anyone? Will it eventually dry? Suggestions?
Cheers.
downwithfloors is offline
Old 01-13-2008, 04:12 AM   #2
feelhigh's Avatar
Trade: Genfut Corporation
Re: Stain Won't Dry!!!
Maybe you can use some special tools make the floor dry.
feelhigh is offline
Old 01-13-2008, 08:40 AM   #3
GoodHouse's Avatar
Trade: Flooring
Rewards Points: 75
Here is your problem. Wood is a porous material, and once you fill those pores up with a stain it will not absorb anymore, hence it just sits on top. 3 coats of stain is a lot. Especially if you brushed it on. I am just taking a guess here but your floor must look blotchey/streaky/cloudy. To fix this i would put some paint thinner on a white buffer polish pad and buff the floor. It will clean up all that heavy stain residue and you go back and dry it with some cotton rags. It wont leave marks and should make your stain coat look even. Good luck
GoodHouse is offline
Old 01-13-2008, 08:52 AM   #4
Knowledge Factory
Floordude's Avatar
Rub on, rub off??? Are you trying to coat with it, instead of stain???
Goodhouse has you pointed in the right direction.
http://www.AustinFloorguy.com
Floordude is offline
Old 01-13-2008, 09:40 AM   #5
Actually, the stain applied evenly with a rag, rubbing in, and rubbing off the excess. There's no blotchiness, cloudiness, or uneven distribution. Like I said, I've never had this problem before. I'm going to the job site to check it out now. Thanks for the advice.
Old 01-13-2008, 09:49 AM   #6
Edger Boy's Avatar
Trade: Wood Floor Contractor
Rewards Points: 25
Down,
Why three coats? What oil-based stain are you using?
Edger Boy is offline
How to stain a grained fiberglass door?? Dorman Painting Painting & Finish Work 7 12-26-2007 05:39 PM
Recoating with Stain on Walls plazaman Painting & Finish Work 5 06-05-2007 09:58 PM
Pricing stain work airborneSGT Painting & Finish Work 3 03-27-2007 08:36 PM
Stain b/4 or after installation??? pitterpat Painting & Finish Work 10 10-09-2006 07:15 AM
Stain trim b/4 or after installation pitterpat Carpentry 3 10-08-2006 11:09 PM
