Stain Not Drying
Old 12-02-2008, 08:33 AM   #1
wayne3434's Avatar
Trade: carpenter/remodeling
Stain Not Drying
its been 24 hrs and the stain on hardwood hasnt dried its sticky but if u walk on it u leave a footprint not familiaR WITH FLOORING SO NOT SURE WHAT TO DO?
wayne3434 is offline
Old 12-02-2008, 09:02 AM   #2
Handle It!
MALCO.New.York's Avatar
Re: Stain Not Drying
Wait a bit longer???? Ventilate better???? Manage Temperature????
Ultimate Wisdom---------
MALCO.New.York is online now
Old 12-02-2008, 09:18 AM   #3
General Contractor
Snow Man's Avatar
Trade: Construction Management
Did you stir it ?
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 12-02-2008, 09:18 AM   #4
Handle It!
Originally Posted by Snow Man View Post
Did you stir it ?
That CERTAINLY could have a lot to do with it!!!
Old 12-03-2008, 07:02 AM   #5
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
What kind of stain? Did you leave it on the surface when it called for being wiped off after application?
http://www.morrispaint.com
gideond is offline
Old 12-03-2008, 09:28 AM   #6
wayne3434's Avatar
i did stir it but i didnt wipe it down and i should have i never do floors always sub them out but it was small section in my house so decided to do it myself. now that it is dry i was going to give it light sanding with 220 grit sandpaper then 2 coats of poly does that sound right?
Old 12-03-2008, 09:54 AM   #7
Ron6519's Avatar
You put too much stain on the floor. Take some thinner and remove the stain. If it's too light afterwards, apply another coat. Let it soak in for 10-15 minutes and wipe off the excess with a cotton rag. An old undershirt works well.
Ron
Ron6519 is offline
Old 12-03-2008, 09:56 AM   #8
Handle It!
I would like to bet that it may be "Dry" but NOT YET "Cured". There are reasons for the wipe down.
The sanding will take it down to a better state, but it may require a second PROPER application to make it "Right".
I do not really know. I only have done this once and it was 25 years ago.
Old 12-03-2008, 12:24 PM   #9
jamestrd's Avatar
Trade: wood flooring
Let me guess?
Minwax stain?
Bought it at HD or something?
Minwaxs new 350 VOC formula takes too long to dry because too many solids..
you need the old formula, which is packaged in quarts only..250 VOC I belive it is..never buy the gallon cans..you will wait 2 days at least for it to dry especially if you havent wiped excess..
conditions underneath the flooring can have a bearing too, say unfinished basement with heavy humidity/moisture..
but i sense it was new minwax..
Your VOCs laws are as stirngent as here in NJ,so you probably have these products on the shelves..
buy quarts instead of gallons.
jamestrd is offline
Old 12-03-2008, 02:24 PM   #10
wayne3434's Avatar
thats exactly what i used its dry now should i use the thinner to remove or would i b ok sanding it lightly then just applying couple coats of poly?
Old 12-03-2008, 02:36 PM   #11
jamestrd's Avatar
if its dry and looks good, you dont need to do anything but start coating..vacuum first..
if it looks uneven, cant give you the fix without seeing it, but most likely, need to sand the area again and re stain it..whole floor shouldnt require another coat and will take even longer to dry...the new stains seal up the wood very well, so it will just lay there...
jamestrd is offline
Old 12-03-2008, 03:00 PM   #12
wayne3434's Avatar
sounds good thanks for all your help will let u know it turns out
Old 12-04-2008, 09:24 AM   #13
Knowledge Factory
Floordude's Avatar
Stain is not a coating. Too much and left there can cause finish adhesion problems.
Shouldn't this thread be in the DIY forum?
http://www.AustinFloorguy.com
Floordude is offline
Old 12-04-2008, 09:27 AM   #14
Handle It!
Upon viewing his post History...............I COULD NOT agree more!!
Old 12-06-2008, 03:01 AM   #15
THE FINISHER
lawndart's Avatar
Trade: Finish Carpenter
Send a message via AIM to lawndart
I've seen this about a dozen times this year alone. Will the guys at HD please tell these DIY'ers to wipe off the stain lol. Matter of fact, I do believe it tells you this on the back of the can. READ THE INSTRUCTIONS NEXT TIME!!!! lol gotta love the noobs. next time call a professional.
lawndart is offline
gel stain door debate Traditions2 Painting & Finish Work 7 11-05-2008 09:27 AM
How to refinish and stain oak plywood cabinets in a salon PAPADORF Painting & Finish Work 9 11-02-2008 08:45 AM
Removing Stain PooZilla Painting & Finish Work 3 09-24-2008 10:35 PM
Removing Stain PooZilla Pressure Washing 1 09-24-2008 11:17 AM
Stain trim b/4 or after installation pitterpat Carpentry 3 10-08-2006 11:09 PM
