Slate Tile For Outside Patio?
Old 07-26-2006, 11:56 PM   #1
Developer
ridgeline_dev's Avatar
Trade: Development
Send a message via AIM to ridgeline_dev
Ok, we are doing a job and the plan is to put some type of slate/ceramic over the cement patio to give it a finished look. I have heard slate does not do well outside (especially in freezing climates).
However, I have heard Quartzite has a very similar look to slate but has the resistance to withstand the elements.
Anyone have any experience with this, or any input to help us decide.
Thanks.
James
-Ridgeline Development
ridgeline_dev is offline
Old 07-27-2006, 02:48 AM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Slate Tile For Outside Patio?
I know that Porcelain will do well.
Floorwizard is offline
Old 08-03-2006, 12:22 AM   #3
diego79's Avatar
Trade: Grout & Tile Restoration
Send a message via AIM to diego79 Send a message via Yahoo to diego79
I would stay away from most slate.
Go with an man made product, that have some really nice porcelain/ceramics out there that you may be very happy with.
Tampa Tile & Grout Cleaning
"All you need in this life is ignorance and confidence,
and then success is sure".
-Mark Twain
diego79 is offline
Old 08-19-2006, 10:00 AM   #4
Trowel Monkey
Shaughnn's Avatar
Trade: Tile & Stone Contractor
Hello James,
There are some very good stone-pattern porcelains available today, that have a broad range of stamping and color applications. The old stone-look porcelains looked cheap because the manufacturers used too few stamping templates and the color was usually "spotty". All fixed now!
What's the condition of the pad you'll be setting to and what's the weather like in your area?
Best of luck,
Shaughnn
Shaughnn is offline
Old 08-20-2006, 05:43 PM   #5
Developer
Trade: Development
I am located in Denver, CO...so the winters are fairly mild, but we do get snow. As far as the slab goes, it is in excellent shape. I can't find a crack in it anywhere.
Thanks.
James
Old 08-20-2006, 08:31 PM   #6
stacker's Avatar
Trade: masonry
i am currently on a job where the homeowner is putting down 16x16 slate on the front and back porches.about 1200 sf.this is some rough stuff,i am having hell tring to keep the tile smooth.also,th ho wants 1/4 grout joints,but tile are not all square,so i am having to eyeball,with some bigger and some smaller grout joints.and to top it off,i have to wait for the ho "enhance"the tile before i can grout.all i can say is it is a pain in the azz and would recommend anything other than slate
stacker is offline
Old 08-20-2006, 09:51 PM   #7
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Go to Florida Tile on Jason st and check out Pietra Art Slate.
Mike Finley is offline
installing slate tile stacker Flooring 13 06-26-2009 04:32 PM
outdoor covered patio - tile? ruger9 Ceramic & Stone Tile 9 07-13-2007 11:57 AM
Slate tile finishing Stevo Flooring Picture Post 10 04-12-2007 04:41 PM
Slate Tile highlife77 Flooring 4 03-01-2007 06:23 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
