Slate Tile
Old 02-24-2007, 05:47 PM   #1
When It Rains, It Pours..
highlife77's Avatar
Trade: Remodeling(Everything)
Slate Tile
I was just wondering about sealing a slate floor, I know there is alot of arguments between crews on sealing the tiles before you set them ..setting them ,sealing them, grouting them and sealing them again. Setting them , grouting them and then sealing the. Is there a right way here? I have done all except sealing them before installing them...it just seems to be time consuming!! I have also used a Mason Bag to grout 350sf one time and I lost my a*s on that job...I just figured it would be faster than trying to scrub the grout out of all the cracks. Also has anyone ever used a Urethane over a slate floor after sealing? I would like to try that on a floor at my house first but I wondering if it will start flaking up after a few years...I was gonna do about 3 coats brushed on.
"When It Rains, It Pours"....
highlife77 is offline
Old 02-24-2007, 05:50 PM   #2
Forry's Avatar
Trade: General Contractor, Remodeler
Re: Slate Tile
I set them, then seal/grout release, then grout, then clean and clean and clean and..... then seal again. PITA!!!
Forry is offline
Old 02-28-2007, 11:31 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Slate Tile
there are grout bags that resemble a cake bag for decorating.
Squeezes a nice even stream of grout goop.
Floorwizard is offline
Old 03-01-2007, 05:51 PM   #4
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Re: Slate Tile
If you don't want to buy a grout bag, you can use a heavy duty contractors bag. just nip the corners, not as clean but effective. But if you do it all the time, get the right thing the first time.
Norrrrrrrrrrrrm is offline
Old 03-01-2007, 06:23 PM   #5
highlife77's Avatar
Re: Slate Tile
Yeah well i'm getting ready to grout another one tommorow.it's about 600sq. ft. ..I'm gonna use the grout bag with a sponge grout float...lots of clean sponges and lots of clean water
installing slate tile stacker Flooring 13 06-26-2009 04:32 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
shingle over slate tile Home Serve Roofing 4 05-07-2007 09:21 PM
Slate tile finishing Stevo Flooring Picture Post 10 04-12-2007 04:41 PM
Slate Tile for Outside Patio? ridgeline_dev Flooring 6 08-20-2006 09:51 PM
