If I were going that far, I would remove it all and start from scratch using Kerdi or Nobleseal and then you would be absolutley sure of the integrity of your shower. Right now, you will have a weak spot where you join the new with the old,and if the pan wan't constructed properly, you coould have problems there too.
I am guessing you are only removing the bottom three feet and floor because you are having problems...
Why not do the whole thing right and not have to deal with the upper ones possibly going bad in the future. Also, the wall tiles generally overlap the floor tiles, but as Mike said, if the waterproofing system is done properly, it really doesn't matter
 -Mike-
Falcon Contracting Residential - Commercial
