Sealing Wood Floors : Oil Vs. Water Based Poly
Old 11-29-2005, 09:23 PM   #21
Marco's Avatar
Trade: Hardwood Flooring
Location: The Oak Floors of Marco Los Gatos, CA 408-353-4882
Re: Sealing Wood Floors : Oil Vs. Water Based Poly
Xterra is Duraseals' waterbase.
You should try Parks Universal sealer. It is very, very versitile. Shellac based, quick dry, looks like oil. Problem with straight water is the washed-out look after a few years. No richness. Problem with straight oil is its not going to last as long.
Marco is offline
Old 11-30-2005, 04:15 PM   #22
Donedat's Avatar
Send a message via MSN to Donedat
Hey Marco,
I thought the CA Gov. outlawed the use of hazardous stuff for flooring. Anyway, that's the roomer. So, is it true or can you use Swedish Finish and other oil base products freely down there?
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 11-30-2005, 06:26 PM   #23
Marco's Avatar
There are various loopholes. Sealers were always available in gallons until this year. Straight oil base and swedish have only been available in quarts for a long time. Finishes got lumped in with paints and the manufacturers managed to keep th quart loophole open for homeowners who needed to match their paint. Result is floor shops buying pallets of quarts. Was supposed to have been closed a long time ago but some quirk left it open, Ive forgotten what. The benefit is that we can still get the good oil, unlike what some eastern states are going through with low-voc formulas. I wish they had closed it all off, create an even playing field with water-base. Oil stains are quarts only. Not sure what is going to happen if they get banned. There are no good water base stains.
One of the ironies is that its ok for a contractor to use cases of quarts of oil, but if he puts two quarts in a bucket, he broke the law.
Marco is offline
Old 11-30-2005, 11:49 PM   #24
Donedat's Avatar
Wow, I didn't realize it was that serious there. A few years ago I did a dance hall where I used 45 gallons of Glitza. 15 gallons per coat. I had 3 5 gallon cans mixed and ready to go for each coat.
I have less waste with Swedish finish than I do with water base. What happens to the left over water finish?
Donedat is offline
Old 12-01-2005, 01:50 AM   #25
Marco's Avatar
Mix it with water and water the plants. Or just leave the jug open, but I usually just use it for first coats. Too expensive for plant food.
Marco is offline
Old 12-01-2005, 11:19 AM   #26
Donedat's Avatar
I suppose if that is all you use is water based finish, then there is little waste there. I primarily use Synteko Classic. When ever I use water finish, the left overs usually sit around just go bad.
Never tried watering the plants with it. Might make them a little stiff.
Donedat is offline
oil based then poly lornmastro Painting & Finish Work 4 03-18-2007 11:18 PM
Stain wood floors navco1390 Flooring 3 03-01-2007 09:48 PM
Painting wood floors steve-in-kville Painting & Finish Work 6 12-25-2006 09:28 AM
Oil base or water base poly? jhf469 Flooring 4 11-24-2006 11:36 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
