Sealing Sub Floors
Old 08-20-2009, 02:19 PM   #1
AcademyHardwood's Avatar
Trade: AcademyFloor
Sealing Sub Floors
I was speaking with my contractor friend Juan the other day and he was telling me that no matter what Hardwood species you use, you must always seal a concrete slab.. I was told that it is not necessary if you are going to install Engineered Hardwood, for it is resistant to the moisture that may come from the concrete. I'm confused.. do i need to seal the concrete sub floor or can i just glue the engineered hardwood directly over the concrete (since it is designed for that lol) ?
AcademyHardwood is offline
Old 08-20-2009, 07:23 PM   #2
finaltouchfloor's Avatar
Trade: Flooring & Remodeling
Re: Sealing Sub Floors
You normally only seal sub-floors for solid hardwood or bamboo , i use Mapai WFM or Bostik MVP . I offer to seal the floors with sealcrete for engineered floors, you can buy it at Sherwin Williams & Kelly Moore . Home depot or Lowes might still sell it.
Sealcrete works well for engineered floors if you have a low to medium moisture content in your sub-floor and want a little insurance.
Mapai will guarantee the floor from failing for 10 years with a moisture reading up to 8 if you use their WFM sealer with new trowels.
finaltouchfloor is offline
Old 08-20-2009, 07:28 PM   #3
Teetorbilt's Avatar
I always seal a slab with two coats no matter what is going down. It's really cheap insurance.
Make sure that your cust. knows this, it will set you apart from other bids.
Albert Einstein
Teetorbilt is offline
Old 08-20-2009, 08:17 PM   #4
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
The engineered wood itself is not resistant, but the 6 mil poly you put down before the pad is.
Floorwizard is offline
Old 08-20-2009, 09:29 PM   #5
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Do you mean a sealer or a vapor retarder?
Mike Costello is offline
Old 08-20-2009, 11:09 PM   #6
What sealer do you use?
Old 08-21-2009, 04:38 PM   #7
ian @antex western
ian@prosource's Avatar
Trade: flooring
I have always a DPM of one form or another on crete floors when installing wood, (type of dpm changes with type of installation ect)
In 25 yrs never had a problem due to moisture except in one job
(friends house) road construction outside his house six months after install cracked all his floors, lots of mositure built up under the DPM sheet to the point it worked its way to the sides and back over the top of the DPM sheet and soaked into the laminate. when we took the floor up to find the cause we had to mop the floors, good job we still had our meter readings from prior to install to prove it was dry. never seen mositure like that before, two years later he is still trying to sort it out with the construction company.
ian@prosource is offline
Old 08-21-2009, 10:57 PM   #8
Knowledge Factory
Floordude's Avatar
Hehehehe!!!!
If the concrete tests to be way below moisture emission or rH levels, there is no reason a moisture blocker membrane is needed, adhesive alone will work just fine for years, unless there is a flood. If moisture testing is close to the limit, use a moisture blocker, engineered or solid wood.
What are the limits?
3-lb. per 1000sq.ft. minimum of 3 test per the first 1000, and 1 additional for each 1000.
75%rH, internal slab humidity
4.5 on the upper scale of a Tramex concrete meter.
@ $150 per 5 gallons, and a spread rate of 30 sq.ft per gallon, I would call it "cheap" insurance. That is a $1 per ft. my cost, no mark-up, and that doesn't include application labor.
http://www.AustinFloorguy.com
Floordude is offline
Tags
hardwood flooring
Wood floors in an elevated bay house (Texas) Monarchy Flooring 22 01-30-2010 12:01 PM
scored concrete floors with metal inserts go do it General Discussion 3 06-30-2009 07:53 AM
Bouncy Floors greenley Carpentry 33 02-26-2009 11:24 PM
Refinish Hardwood Floors... What's with the spots?!? (pics attached) danimal Flooring 12 02-14-2009 02:50 PM
Epoxy Garage Floors RoSSco Painting & Finish Work 8 09-04-2008 11:00 AM
