Screwed Up On The Stain !!
Old 09-30-2009, 02:28 PM   #1
AcademyHardwood's Avatar
Trade: AcademyFloor
Heres the Scenario, he scoured the floors with a buffer and a water based cleaning soultion then let it dry. From then on he sanded the floors down with a 120 grit, then to a 220 grit, because the floors hadnt been finished prior, so it was fairly easy...the only down fall was the floors are pine and it became cupped where they are joined by the tounge and groove, so when he was sanding (with out taking a good portion off the floor), he couldnt get it flat. That being said there were coloration differences so he couldnt just throw down a poly, it wouldnt look unified, so he went with a stain. His wife went to lowes and got a min wax water based stain they suggested to her and it was for furniture not hardwood floors... so before he realized it, he had applied it to the 1700 sq. ft of his hardwood floors and after it dried it looked like crap! so he tried to sand down the overlap marks and blend it in... which made it worse. so he went back to lowes and they gave him his money back plus some for inconvience, now the real question i have to sand down the stain again... and start all over, but... if he uses a fine sandpaper is it possible to sand down the stain to a white wash (by the way the color is desert sand) blend it nicely then poly? or is he flat out screwed and has to sand down to natural wood again?
AcademyHardwood is offline
Old 09-30-2009, 02:42 PM   #2
genecarp's Avatar
Re: Screwed Up On The Stain !!
Wow, what a mess. It is an interesting series of events that led to the current condition of the floor. The answer, like most answers is not straight forward. Of coarse the safe bet would be to sand the whole floor down again and start over. The other option is what we call the EXPERIMENT, sanding out lighly, and going over with a semi trans could produce a wash effect. we have created many a beautiful floors going the EXPERIMENT ROUTE. That is just one approach, take a section of the floor and experiment. Please note you must have a basic understanding of wood/finishing products/application techniques, etcc in order for the shoot from the hip approach, if you dont have someone with those skills available, strip it and do it again. G
genecarp is offline
Old 09-30-2009, 06:11 PM   #3
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Post this bull**** over on the DIY site!!....SHEEEEESH...
the big 12 inch is offline
The Following 2 Users Say Thank You to the big 12 inch For This Useful Post:
Cdat (10-02-2009), PrecisionFloors (10-01-2009)
Old 10-01-2009, 02:09 PM   #4
JK Floors's Avatar
Trade: Flooring installation
Academy, you presented yourself as a pro. You started by cutting and pasting articles and then started to ask beginner type questions. I hope your customers don't search on the web. Good chance they'll catch the fact that you are in over your head most of the time.
JK Floors is offline
The Following 3 Users Say Thank You to JK Floors For This Useful Post:
astor (10-01-2009), Cdat (10-02-2009), the big 12 inch (10-01-2009)
Old 10-02-2009, 12:35 PM   #5
Trade: AcademyFloor
Wow u know alot about me.. im impressed. I guess my post arent working.. I would use one of the smiley faces, but i realized im not a complete retard.
Hate it or love it, the underdogs on top.
Old 10-02-2009, 12:56 PM   #6
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
You screwed up a floor and/or you obviously don't know a lot about finishing wood...how does that put you on top?
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is online now
Old 10-02-2009, 10:50 PM   #7
monkey's Avatar
Trade: painter/carpenter
I don't usually do this but.....
"your the top...your the tower of pizza(pisa)
you're the smile...on the mona lisa
if I'm the bottom then baby you're the top!"
Originally Posted by Steve Richards View Post
Just so you know...Your mother is the one that picked "Sue"."Monkey" was my idea.
Never let anyone tell you that Monkey Sue Richards isn't a nice name.
monkey is offline
Old 10-03-2009, 03:56 AM   #8
ger_xiong's Avatar
Trade: Hardwood Floors
Floors will need to sanded back down with an eighty or one hundred grit. Buff the floors with a 120 grit mesh screen, pop the grain using water to minimized uneven color in the wood. ( recommended for softwood. )
220 is a little fine for staining - color will appear uneven and poor.
ger_xiong is offline
The Following User Says Thank You to ger_xiong For This Useful Post:
TopFloor (10-18-2009)
Tags
hardwood flooring, hardwood stain
Final coating on stain grade doors Mike Finley Painting & Finish Work 1 09-20-2009 11:36 AM
Paint or stick with solid color stain? JL1 Painting & Finish Work 41 07-28-2009 08:44 AM
Stain Gurus, thoughts please moorewarner Painting & Finish Work Picture Post 1 07-01-2009 04:57 PM
Removing Stain PooZilla Painting & Finish Work 3 09-24-2008 10:35 PM
Removing Stain PooZilla Pressure Washing 1 09-24-2008 11:17 AM
